Thin cylinder walls = prone to overheating myth or not? #2706435
10/13/19 04:05 PM
10/13/19 04:05 PM
Eagle, Idaho
Neil Offline OP
The Doctor is in.
Neil  Offline OP
The Doctor is in.
Eagle, Idaho
I'm sure everyone who has been around old cars has heard the tale not to mess around with engines that have been bored over too much as that can cause them to overheat. In my mind, as small as it is grin, the amount of material removed between a .0.30 over block and say 0.60 block seems miniscule in the big picture so perhaps this may be just an old wives tale that clings to the hobby even today?
It would seem that a block with thinner walls would transfer heat into the water jackets faster and therefor run cooler? Perhaps the thin wall block actually puts heat into the water jackets too fast and the cooling system can't keep up?
The block with the thicker walls would retain heat longer as there are more metal molecules in play. To me this would be a slight negative as the heat transfer process to the water in the block would be slower vs a thin wall block.
Anyone ever have any real world experience with rebuilding an engine only to have it run hotter afterwards?
Discuss?
Re: Thin cylinder walls = prone to overheating myth or not? [Re: Neil] #2706438
10/13/19 04:22 PM
10/13/19 04:22 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
As thin as the BB mopars are with a standard bore, I would say it is mostly a myth. to thin just cracks
Re: Thin cylinder walls = prone to overheating myth or not? [Re: Neil] #2706451
10/13/19 05:33 PM
10/13/19 05:33 PM
PA
70Duster Offline
70Duster  Offline
PA
From a thermodynamic perspective, it's a myth.
Re: Thin cylinder walls = prone to overheating myth or not? [Re: Neil] #2706660
10/14/19 11:15 AM
10/14/19 11:15 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Discuss?
I have heard of a couple engines running a slightly hotter (10 deg or so) after a fresh rebuild, but their owners and I attribute it more to new bearings and tighter clearances--not thinner bore walls.
In both cases after a few hundred miles, the engine temps returned to "normal".
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Thin cylinder walls = prone to overheating myth or not? [Re: wingman] #2706846
10/14/19 10:12 PM
10/14/19 10:12 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
This theory would condem all engines made in the last 35 years.
Re: Thin cylinder walls = prone to overheating myth or not? [Re: wingman] #2706977
10/15/19 12:24 PM
10/15/19 12:24 PM
Discuss?
Increase heat tells me the motor has more friction due to the fresh cylinder walls being rougher than before the rebuild, especially when it goes back to normal after break in work
Re: Thin cylinder walls = prone to overheating myth or not? [Re: Cab_Burge] #2707389
10/16/19 08:38 PM
10/16/19 08:38 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
This is my take on this topic. Think of the cylinder wall as a layer of insulation between hot gasses and cold coolant. The thinner the insulation, the more heat transfer will occur from the hot side to the cold side. Thermodynamics says the cold side (coolant) temperature will increase. But is it significant? Who knows. I'm not going to attempt to quantify it.
