trans mount help! cast iron to 727 #2706211
10/12/19 02:12 PM
10/12/19 02:12 PM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
So I have a 61 dart, the big one, and swapped out the cast iron trans for a 727, problem is I need a trans rear mount, does anyone know if a stock mount will work or is there an aftermarket??
Re: trans mount help! cast iron to 727 [Re: Blown61] #2706219
10/12/19 02:50 PM
10/12/19 02:50 PM
Cab_Burge Online work
Cab_Burge  Online Work
Make some measurements on both, probably not a bolt in whiney shruggy scope
I've own both but never tried to swap one from a early car to a later or vise a versa.
What are you going to do about the shifter if it is going to a 1962 to 1965 push button shift cable tranny ?
Re: trans mount help! cast iron to 727 [Re: Blown61] #2706237
10/12/19 04:37 PM
10/12/19 04:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Year of the 727 matters, mount pad location changed.
