69 RR Hemi brake question #2706109
10/12/19 07:17 AM
10/12/19 07:17 AM
Bradenton, Florida
Rich Offline OP
Rich  Offline OP
Bradenton, Florida
Was power brakes standard on all 1969 RR hemi cars? If manual brakes would it be disc or drum in front?
1968 GTX Black on black survivor (gone)
1969 Roadrunner B5 with white (gone)
2016 Plum Crazy Hellcat Challenger (gone)
2019 B5 Redeye widebody Challenger (gone)
2022 Frostbite Redeye Widebody Challenger...keeping this one
Re: 69 RR Hemi brake question [Re: Rich] #2706119
10/12/19 08:25 AM
10/12/19 08:25 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
No. My current car is a 3.54 geared track pack 4 wheel manual drum brake. My previous hemi RR was a 4.10 gear super track pack with power front disc brakes.
1969 Hemi Roadrunner 2nd owner
Re: 69 RR Hemi brake question [Re: 69hemibeep] #2706332
10/13/19 07:38 AM
10/13/19 07:38 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I have a question. If a 68 hemi RR had power DRUM brakes, would it still have the offset Bendix dual diaphragm unit. I have a customer that need a booster for that application.
Re: 69 RR Hemi brake question [Re: Rich] #2706375
10/13/19 11:36 AM
10/13/19 11:36 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Manual drum brakes were standard equipment UNLESS either the disc brakes option was checked on the option sheet OR an axle pkg was ordered.
Such as,
Super Perf ( auto trans ) or Super track pack ( 4 spd cars ) upgrades the rear axle to a Dana and adds power front disc brakes ( manual disc brakes were not avail in a B body )
In regards to a hemi and power drum brakes, I ' think ' the same bendix booster and brackets were used , just with a drum brake master cylinder
Re: 69 RR Hemi brake question [Re: gtx6970] #2706384
10/13/19 12:18 PM
10/13/19 12:18 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
yes, same offset mounted Bendix dual diaphragm booster drum & disc
Re: 69 RR Hemi brake question [Re: 6bblgt] #2706385
10/13/19 12:20 PM
10/13/19 12:20 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Thanks. Now I just need to locate the correct rod to the brake pedal.
Re: 69 RR Hemi brake question [Re: fastmark] #2706611
10/14/19 08:35 AM
10/14/19 08:35 AM
VA
dragon slayer Offline
VA
I am confused, for the hemi powered drum the bracket assembly has the pushrod for the brake pedal. You implied you needed a booster? If you have the bracket assembly for a hemi you have the pushrod to the pedal (if it is complete).
