Re: alternator amps [Re: mopar dave] #2707233
10/16/19 10:57 AM
10/16/19 10:57 AM
moparx Offline
moparx  Offline
i'm with dave on the powermaster stuff. i have not had luck with their products as well, although this has been repairing wiring issues for others.
also, every single one wire alternator i have been around doesn't charge worth a darn below 15-1800 rpm. if you have belt issues, they are even worse.
another thing to think about, is the "start up amps" for your electric cooling system can be quite a bit higher than the running amp draw, causing you to need a higher than 35 amp output on your alternator.
in my opinion [only], a 90 amp denso would be the starting point.
my opinion, your horsepower will vary.
beer
Re: alternator amps [Re: moparx] #2707383
10/16/19 08:20 PM
10/16/19 08:20 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
94 geo metro denso alternator might fit your application and budget.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: alternator amps [Re: astjp2] #2707403
10/16/19 09:21 PM
10/16/19 09:21 PM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
Those have a serpentine pulley and not 1 wire hook up.
Re: alternator amps [Re: rowin4] #2707602
10/17/19 11:33 AM
10/17/19 11:33 AM
moparx Offline
moparx  Offline
i have swapped serpentine pulleys to V belt ones many times.
in my opinion, the three wire hook ups are superior to the single wire units in many ways.
once again, my opinion only.
beer
Re: alternator amps [Re: moparx] #2707621
10/17/19 12:13 PM
10/17/19 12:13 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Have a 90 amp 1 wire on my car.
Had the car completely rewired by a professional last winter.
This past racing season( and i street drive it) i never once had a battery charger on the car. Ever
And i went rounds. And always use the electric water pump and fan between rounds and in the lanes to keep temps the same.
Previous 2 years, before wiring upgrade.... numerous issues, slow crank, etc, etc
All i can say is having wiring in car correct and up to snuff was HUGE upgrade. I wire works spendidly
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
