fresh rebuild. wont go into reverse or park #2705725
10/10/19 10:22 PM
10/10/19 10:22 PM
kelowna
Darrol Offline OP
Darrol  Offline OP
kelowna
First time rebuilding 727. got it back together and installed. haven't added fluid yet. doesn't go into reverse or park. what am i missing. ?
Re: fresh rebuild. wont go into reverse or park [Re: Darrol] #2705852
10/11/19 11:28 AM
10/11/19 11:28 AM
if you disconnect the rod down at the trans horizontle shift lever, can you move the lever into the 6 positions?
Re: fresh rebuild. wont go into reverse or park [Re: RapidRobert] #2705938
10/11/19 03:19 PM
10/11/19 03:19 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Don't feel bad. Anytime I worked on an automatic transmission it never moved again under it's own power.
2011 Drag Pak Challenger
Re: fresh rebuild. wont go into reverse or park [Re: Darrol] #2706065
10/11/19 10:48 PM
10/11/19 10:48 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Won't do much of anything without fluid shruggy Certainly not reverse
Re: fresh rebuild. wont go into reverse or park [Re: RapidRobert] #2706150
10/12/19 10:59 AM
10/12/19 10:59 AM
IMGTX Offline
IMGTX  Offline
I was thinking of all the internal problems and Robert nailed the most common problem right here.
It may just be a linkage problem. Usually an adjustment.
Make sure the levers on the top of the transmission are not hitting anything or each other.
It it stops short of reverse or park pull the pan and have a look inside.
There are a couple places to look first inside the pan.
The only parts of the valve body that move are the parking pawl rod and this shift valve marked with the red arrow.
It is doubtful you could get the valve body in with the rod out of place because it sticks so far out of the main body and into the tail housing but look for interference. Images here -> https://www.jeepforum.com/forum/f8/tf-999-leaking-shift-kick-down-1207701/
Also there is a detent ball assembly under the parking rod make sure it is correctly moving.
