MSD coil restistant #2705507
10/10/19 12:28 PM
10/10/19 12:28 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Anyone here test coils ? curios what type of resistant you all getting? The coil in ? is a MSD pro coil.
Re: MSD coil restistant [Re: racerx] #2705529
10/10/19 01:19 PM
10/10/19 01:19 PM
Cab_Burge Online work
Cab_Burge  Online Work
Is that the little red on?
I have several I can check for you if so up
I have several MSD race coils from the early Mallory to one of the newer transformer type shruggy
Re: MSD coil restistant [Re: Cab_Burge] #2705698
10/10/19 09:20 PM
10/10/19 09:20 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Yes sir......Cab if you can check the primary side and the secondary if you can for me Thaxs. I have one of the Mallory coils here that check 12.5 on the secondary and .3 on the primary. Can't seem to get a reading (resistance) on those secondary side of there pro coils .
Re: MSD coil restistant [Re: racerx] #2705703
10/10/19 09:31 PM
10/10/19 09:31 PM
How are you measuring the coil resistance so I do it the same way? work
Re: MSD coil restistant [Re: Cab_Burge] #2705724
10/10/19 10:21 PM
10/10/19 10:21 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Muti-meter …...measured in ohms 200 in primary,20k in secondary. I can get a measure in the primary but not in the secondary try to check and see if a coil is bad.....Thaxs.
https://www.holley.com/products/ignition/ignition_coils/race/parts/8201
Re: MSD coil restistant [Re: racerx] #2705755
10/11/19 01:29 AM
10/11/19 01:29 AM
Are you measuring across the + to the - post on the coil or measuring from + to the coil output, post and from the - to the coil output post ?
Re: MSD coil restistant [Re: Cab_Burge] #2705776
10/11/19 07:03 AM
10/11/19 07:03 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Yes sir.....+ to - primary...….+ to coil out put secondary.
Re: MSD coil restistant [Re: racerx] #2705900
10/11/19 01:15 PM
10/11/19 01:15 PM
I'm using a Fluke 87 meter and I got .820 K ohm from the - to the coil output, .819K from the + to the coil post and .3K (300 ohms)from the - to the+ posts at 32 degrees F in my car trailer.
Re: MSD coil restistant [Re: Cab_Burge] #2705919
10/11/19 02:12 PM
10/11/19 02:12 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
From MSD
The primary resistance is measured with the probes on the positive and the negative terminals of the coil. This value will vary between coils, but a rule of thumb on MSD’s coils would be between .03 - .7 ohms.
Secondary resistance is measured between the coil + terminal and the secondary tower (where the spark plug connects). This reading also will vary between the make of the coil, but it should be somewhere between 200 – 14,000 ohms! Quite a range. The important thing to look for is that there is not an open or a short in the windings.
Re: MSD coil restistant [Re: Cab_Burge] #2705977
10/11/19 05:15 PM
10/11/19 05:15 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thaxs…. Cab for the effort up That's what I got on the primary's .03 but I can't get a ohms reading on the secondary side of the coil, maybe it's a bad coil shruggy ……….Thaxs for the effort.
