Re: MSD coil restistant
[Re: racerx]
#2705529
10/10/19 01:19 PM
10/10/19 01:19 PM
Posts: 43,296 Bend,OR USA
Cab_Burge
Is that the little red on? I have several I can check for you if so I have several MSD race coils from the early Mallory to one of the newer transformer type
[Re: racerx]
#2705755
10/11/19 01:29 AM
10/11/19 01:29 AM
Cab_Burge
Are you measuring across the + to the - post on the coil or measuring from + to the coil output, post and from the - to the coil output post ?
[Re: racerx]
#2705900
10/11/19 01:15 PM
10/11/19 01:15 PM
Cab_Burge
I'm using a Fluke 87 meter and I got .820 K ohm from the - to the coil output, .819K from the + to the coil post and .3K (300 ohms)from the - to the+ posts at 32 degrees F in my car trailer.
