remote oil filters - where to mount #2704870
10/08/19 02:03 PM
10/08/19 02:03 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I hate how BB Mopar oil filters mount - you can't help but make a mess changing them. So, I plan to use dual remote filters but can't quite figure where to mount them. I want them down low a,d had thought of mounting to the inside of the frame rail below the battery but the K-member is in the way. Any opinions ?? Car is a '69 RR.
Re: remote oil filters - where to mount [Re: Stanton] #2704920
10/08/19 05:40 PM
10/08/19 05:40 PM
Kirkland, Washington
Pacnorthcuda Offline
I like the BB mount. I loosen the filter a little, then wrap two small garbage bags around the filter, and then spin off. Rarely a mess if I do my part correctly.
Re: remote oil filters - where to mount [Re: Pacnorthcuda] #2704927
10/08/19 06:10 PM
10/08/19 06:10 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I recently took off a dual filter set up.I put it in the drivers side wheelwell up high behind the headlight.Still have it laying in the garage..........
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: remote oil filters - where to mount [Re: Pacnorthcuda] #2704930
10/08/19 06:27 PM
10/08/19 06:27 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Exactly how I have done it.
Ok
Re: remote oil filters - where to mount [Re: Stanton] #2704932
10/08/19 06:30 PM
10/08/19 06:30 PM
How about mounting it to the front sub frame between the notch in the K member scope
That should add some oil cooling being down that low and still high enough to not be hurt from speed bumps work up
Re: remote oil filters - where to mount [Re: Stanton] #2704954
10/08/19 07:28 PM
10/08/19 07:28 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The longer the lines, the more important it is to use only big fittings and port the housing. The inside of some of those castings is really crude, you'll know immediately where it needs work. I'm surprised more shops don't offer this as a service, low precision (1mm is good enough to make a difference), just a good grasp of where the fluid wants to go. I port my oil pump bodies too.
With the extra time delay for OP to reach the whirly bits, I'd like to see a small number before the "W" in the oil. I'm running 5W40 (instead of factory 10W30). Yes, it slows down the hot idle speed slightly (think of an electric fan in a bathtub filled with Jello instead of water), and I may have lost a HP or 5. My peace of mind is worth it!
Boffin Emeritus
Re: remote oil filters - where to mount [Re: polyspheric] #2705057
10/09/19 08:25 AM
10/09/19 08:25 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
That is a big waste of money, time and also adds unessecary weight.
The 80s called and want thier dual remote filter setup back.
Planning on running a cool can too? : p
Re: remote oil filters - where to mount [Re: polyspheric] #2705059
10/09/19 08:26 AM
10/09/19 08:26 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
This should read "the longer the lines the more you have wasted money, time and space. This modification is less effective than fuzzy dice"
Lol i will stop now.
Re: remote oil filters - where to mount [Re: Jeremiah] #2705078
10/09/19 09:11 AM
10/09/19 09:11 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
sometimes it is necessary to move the filter as it gets crowded in that area. I understand your sarcasim, but sometimes it is a lot easier to move it to a more accessible spot.
....BAD A$$ STREET CAR.....
Re: remote oil filters - where to mount [Re: n20mstr] #2705091
10/09/19 09:56 AM
10/09/19 09:56 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Cool can arrived last week and the fuzzy dice are en route as we speak - this thing should fly !!!
Re: remote oil filters - where to mount [Re: Stanton] #2705094
10/09/19 09:59 AM
10/09/19 09:59 AM
N
n20mstr Offline
n20mstr  Offline
N
I USE the Peterson remote mount with the pump on top. You add one line from the pan to the remote mount and you can prelube your engine before start up. It pricey , but I prelube my engine with a cordless drill everytime I roll it out of the trailer.
Re: remote oil filters - where to mount [Re: n20mstr] #2705117
10/09/19 10:51 AM
10/09/19 10:51 AM
hemi-itis Offline
hemi-itis  Offline
FWIW I remover the Moroso 3 qt accumulator and the duel filter deal almost 2 years ago when I went on a Lee La Lane diet and lost a total of 200 lbs.
Re: remote oil filters - where to mount [Re: Stanton] #2705194
10/09/19 02:15 PM
10/09/19 02:15 PM
AndyF Offline
AndyF  Offline
I went the other way with my stuff and now I use the mini oil filter from Dodge. It fits better with plenty of room around it and it is easy to change without making a mess.
Re: remote oil filters - where to mount [Re: AndyF] #2705235
10/09/19 05:23 PM
10/09/19 05:23 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Hemi-itis ...
Re: remote oil filters - where to mount [Re: Stanton] #2705237
10/09/19 05:25 PM
10/09/19 05:25 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
This works for me as I also have rear mounted oil cooler and accusump. Make for vey easy/clean oil filter changes.
https://board.moparts.org/ubbthread...ay-protour-practice-car.html#Post1553876
Re: remote oil filters - where to mount [Re: jcc] #2705351
10/09/19 11:26 PM
10/09/19 11:26 PM
hemi-itis Offline
hemi-itis  Offline
That looks like alotta UNneeded weight work
Re: remote oil filters - where to mount [Re: hemi-itis] #2705416
10/10/19 08:26 AM
10/10/19 08:26 AM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL... your talking weight and your running a big heavy blower in a street rod.. myself
I mount the filter where ever its easy to get at on my SB junk.. I'll take the extra
weight on my street stuff... even on my BB 38 street rod I moved it up to the front
so it was easy to get at and I do use big lines on it
wave
Re: remote oil filters - where to mount [Re: hemi-itis] #2705441
10/10/19 09:25 AM
10/10/19 09:25 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I agree, all weight is bad, but the real difference in position is 16' (8' + 8') of #10 braided hose, plus the benefit to me for road race track car, its all low, and its all towards the rear for improved balance.
Everything is a compromise.
Re: remote oil filters - where to mount [Re: jcc] #2705446
10/10/19 09:36 AM
10/10/19 09:36 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
There's no point in running lines any bigger than the opening in the fittings.
