AN fittings
#2704914
10/08/19 05:28 PM
10/08/19 05:28 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Buying some fittings and wanted to ask you guys if there is much of a difference between russel,earls or aeroquip. I see many other names I never heard of besides Jegs & Summit chin house brands. What say ye??
Re: AN fittings
[Re: hemi-itis]
#2704934
10/08/19 06:31 PM
10/08/19 06:31 PM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
I would go with Fragola or Earls, in that order.
Re: AN fittings
[Re: jb500]
#2705006
10/08/19 10:33 PM
10/08/19 10:33 PM
Posts: 1,890 Spahn Ranch
RMCHRGR
Spahn Ranch
Al, SK has XRP brand, some seem to swear by it. I ended up using a bunch of their stuff just because that's what SK carries. It's not bad but I prefer the Russell brand, I have had good luck with it. Since I don't live near SK anymore, I looked at some fittings on Summit the other day and Aeroquip seems to be slightly cheaper than some other brands.
Moreland Belt and Hose in Freeport carries Aeroquip stuff.
'71 Duster '17 Ram 1500
Re: AN fittings
[Re: RMCHRGR]
#2705016
10/08/19 10:56 PM
10/08/19 10:56 PM
Posts: 11,484 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Aeroquip for about 95% of what I've used over the years. Never an issue. Earls, Fragola and the other US made premium brands are fine. XRP is top shelf. Pay attention to the IDs of the hose ends and hard parts. They aren't all the same. And I would recommend using hose and hose ends from the same manufacturer.
Re: AN fittings
[Re: CMcAllister]
#2705018
10/08/19 11:18 PM
10/08/19 11:18 PM
Posts: 7,475 Minnesota
Hemi_Joel
Minnesota
I measured the i.d. of some various brands of fittings. The Fragola was biggest. I can't remember the other brands, but it was not a large sampling. So I usually use fragola
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: AN fittings
[Re: Hemi_Joel]
#2705023
10/08/19 11:54 PM
10/08/19 11:54 PM
Posts: 6,135 Melbourne , Australia
LA360
I use Australian made Speedflow, I avoid the chinese made stuff. I've used Earls and Aeroquip in the past, it was fine. No experience with Fragola or XRP
An interesting point was brought up about the ID of some of the chinese fittings, I have seen some of the 'FULL flow" fittings having a much smaller ID
Alan Jones
Re: AN fittings
[Re: LA360]
#2705047
10/09/19 07:23 AM
10/09/19 07:23 AM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
My car is mostly Fragola with a little bit of aeroquip mixed in. The Fragola is a usually a little cheaper and it is a nice product.
68 Barracuda Formula S 340
Re: AN fittings
[Re: A/MP]
#2705099
10/09/19 10:09 AM
10/09/19 10:09 AM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
I use the Earls UltraPro fittings and hose. High quality Teflon lined easy to assemble and made in USA. They have an excellent selection. I’ve also used XRP with good results. They have some specialty items others don’t have.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: AN fittings
[Re: Cab_Burge]
#2705105
10/09/19 10:19 AM
10/09/19 10:19 AM
Posts: 4,269 Morrow, OH
markz528
Morrow, OH
Fragola I had no idea that Fragola is less than 10 miles from where I grew up. They are in Southington CT.
Re: AN fittings
[Re: RMCHRGR]
#2705111
10/09/19 10:35 AM
10/09/19 10:35 AM
hemi-itis
Moreland Belt and Hose in Freeport carries Aeroquip stuff. I don't go to SK as often as I used to.Unless I have a tow bringing me out there the are over 20 miles away. Although they match the mail order guys it's still $25 in diesel for me to get out there. The free shipping is hard to beat. I have alot of Russel stuff on there so for now That's what I will use. Maybe one day Cotton braided and black fittings will replace all the steel but.................. For now I'm adding a pair of NOS plates to use as an intercooler.Tech told me 44 jets will give me 50 hp from each plate and lower the IAT over 100* so more than 6 lbs of boost can be used. I am a little over a half a second away from my goal and legal limit and that's IT!!!
Re: AN fittings
[Re: hemi-itis]
#2705503
10/10/19 12:14 PM
10/10/19 12:14 PM
Posts: 1,430 Martinsville, IN
cdwmotorsports
Martinsville, IN
I use Aeroquip and Fragola mostly, Earl's and Russel are also used in small doses. I really like the Fragola stuff though.
eBay-cdwmotorsports
Re: AN fittings
[Re: hemi-itis]
#2705514
10/10/19 12:40 PM
10/10/19 12:40 PM
Posts: 25,726 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I've been using the Summit fittings since they were introduced, no issues; none of my pressures exceed 200 psi. My only complaint is that some of them have metric hex.
