Re: remote oil filters - where to mount
[Re: Pacnorthcuda]
#2704927
10/08/19 06:10 PM
10/08/19 06:10 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I recently took off a dual filter set up.I put it in the drivers side wheelwell up high behind the headlight.Still have it laying in the garage..........
[Re: Pacnorthcuda]
#2704930
10/08/19 06:27 PM
10/08/19 06:27 PM
Posts: 1,098 Massillon, Ohio
cudatom
Massillon, Ohio
I like the BB mount. I loosen the filter a little, then wrap two small garbage bags around the filter, and then spin off. Rarely a mess if I do my part correctly. Exactly how I have done it.
Ok
[Re: Stanton]
#2704954
10/08/19 07:28 PM
10/08/19 07:28 PM
Posts: 4,206 New York
polyspheric
New York
The longer the lines, the more important it is to use only big fittings and port the housing. The inside of some of those castings is really crude, you'll know immediately where it needs work. I'm surprised more shops don't offer this as a service, low precision (1mm is good enough to make a difference), just a good grasp of where the fluid wants to go. I port my oil pump bodies too. With the extra time delay for OP to reach the whirly bits, I'd like to see a small number before the "W" in the oil. I'm running 5W40 (instead of factory 10W30). Yes, it slows down the hot idle speed slightly (think of an electric fan in a bathtub filled with Jello instead of water), and I may have lost a HP or 5. My peace of mind is worth it!
Boffin Emeritus
[Re: polyspheric]
#2705057
10/09/19 08:25 AM
10/09/19 08:25 AM
Posts: 9,099 Rogue River, OR
Jeremiah
Rogue River, OR
That is a big waste of money, time and also adds unessecary weight.
The 80s called and want thier dual remote filter setup back.
Planning on running a cool can too? : p
[Re: polyspheric]
#2705059
10/09/19 08:26 AM
10/09/19 08:26 AM
Jeremiah
Rogue River, OR
The longer the lines, the more important it is to use only big fittings and port the housing. The inside of some of those castings is really crude, you'll know immediately where it needs work. I'm surprised more shops don't offer this as a service, low precision (1mm is good enough to make a difference), just a good grasp of where the fluid wants to go. I port my oil pump bodies too. With the extra time delay for OP to reach the whirly bits, I'd like to see a small number before the "W" in the oil. I'm running 5W40 (instead of factory 10W30). Yes, it slows down the hot idle speed slightly (think of an electric fan in a bathtub filled with Jello instead of water), and I may have lost a HP or 5. My peace of mind is worth it! This should read "the longer the lines the more you have wasted money, time and space. This modification is less effective than fuzzy dice" Lol i will stop now.
[Re: Jeremiah]
#2705078
10/09/19 09:11 AM
10/09/19 09:11 AM
Posts: 4,673 On the parachute mount
n20mstr
Planning on running a cool can too? : p sometimes it is necessary to move the filter as it gets crowded in that area. I understand your sarcasim, but sometimes it is a lot easier to move it to a more accessible spot.
....BAD A$$ STREET CAR.....
[Re: Stanton]
#2705094
10/09/19 09:59 AM
10/09/19 09:59 AM
n20mstr
I USE the Peterson remote mount with the pump on top. You add one line from the pan to the remote mount and you can prelube your engine before start up. It pricey , but I prelube my engine with a cordless drill everytime I roll it out of the trailer.
[Re: n20mstr]
#2705117
10/09/19 10:51 AM
10/09/19 10:51 AM
hemi-itis
FWIW I remover the Moroso 3 qt accumulator and the duel filter deal almost 2 years ago when I went on a Lee La Lane diet and lost a total of 200 lbs.
[Re: Stanton]
#2705194
10/09/19 02:15 PM
10/09/19 02:15 PM
Posts: 30,998 Oregon
AndyF
I went the other way with my stuff and now I use the mini oil filter from Dodge. It fits better with plenty of room around it and it is easy to change without making a mess.
[Re: hemi-itis]
#2705416
10/10/19 08:26 AM
10/10/19 08:26 AM
Posts: 52,972 Romeo MI
MR_P_BODY
That looks like alotta UNneeded weight LOL... your talking weight and your running a big heavy blower in a street rod.. myself I mount the filter where ever its easy to get at on my SB junk.. I'll take the extra weight on my street stuff... even on my BB 38 street rod I moved it up to the front so it was easy to get at and I do use big lines on it
[Re: hemi-itis]
#2705441
10/10/19 09:25 AM
10/10/19 09:25 AM
Posts: 22,696 Bitopia
jcc
Bitopia
That looks like alotta UNneeded weight I agree, all weight is bad, but the real difference in position is 16' (8' + 8') of #10 braided hose, plus the benefit to me for road race track car, its all low, and its all towards the rear for improved balance. Everything is a compromise.
