Hotchkis B/E UCA’s with a 13” and larger brakes anyon #2700799
09/25/19 02:44 PM
09/25/19 02:44 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Is anyone running this combo? I’m looking to make this my final upgrade to the suspension and I seem to remember that they was an issue with the ball joint or some other clearance issue with the kit.
I’ve got the Dr. Diff 14.25” kit with a viper caliper.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Hotchkis B/E UCA’s with a 13” and larger brakes anyon [Re: AlexP] #2700855
09/25/19 04:49 PM
09/25/19 04:49 PM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
Not sure about teh Andy F stuff, but Willwood, Baer and Stoptech in the 13"+ range work fine.
Re: Hotchkis B/E UCA’s with a 13” and larger brakes anyon [Re: 68rrunner] #2704722
10/07/19 09:46 PM
10/07/19 09:46 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
so buy different UCA's, that would give you the super big brakes and I am not impressed with hotchkiss stuff. I think that Heims are [censored] joints for steering. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Hotchkis B/E UCA’s with a 13” and larger brakes anyon [Re: AlexP] #2706444
10/13/19 04:41 PM
10/13/19 04:41 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I have this combo hotchkis arms 13" viper calipers - the only problem I had was I couldn't run the 17" rims I wanted - upgraded to 18"
Re: Hotchkis B/E UCA’s with a 13” and larger brakes anyon [Re: dangina] #2709914
10/25/19 12:37 AM
10/25/19 12:37 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Are you calipers mount in the front or in the back?
The Hotchkis A-body arm have a wide turn in the rear and can interfere with some rear mounted calipers. I think E-body's don't do that.
Re: Hotchkis B/E UCA’s with a 13” and larger brakes anyon [Re: autoxcuda] #2710167
10/26/19 02:12 PM
10/26/19 02:12 PM
Kings Beach, CA
tahoechallenge Offline
Kings Beach, CA
I run this 15" setup. The calipers are rear mounted with Hotchkis arms.
Re: Hotchkis B/E UCA’s with a 13” and larger brakes anyon [Re: tahoechallenge] #2710255
10/26/19 08:55 PM
10/26/19 08:55 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
A 15" brake with a wheel adapter eek?
Got to be more behind that story.
Re: Hotchkis B/E UCA’s with a 13” and larger brakes anyon [Re: jcc] #2710333
10/27/19 10:17 AM
10/27/19 10:17 AM
moparx Offline
moparx  Offline
i was looking mainly at the rotor surface.
i hope that's just a reflection from the camera ?
beer
Re: Hotchkis B/E UCA’s with a 13” and larger brakes anyon [Re: moparx] #2710354
10/27/19 11:48 AM
10/27/19 11:48 AM
Kings Beach, CA
Kings Beach, CA
I need the spacers to run the Mustang bullitt wheels. I used them with the original disk setup as well. The brakes are from a 2015 Mustang. They were new take-offs that I bought on eBay for $300. I use the 15/16" power master cylinder. I have been running this setup for three years and it works great! At some point I would like to get new 18" wheels with the correct offset. But not today....
The grove in the rotor is just a scratch that occurred when I mocked everything up.
Re: Hotchkis B/E UCA’s with a 13” and larger brakes anyon [Re: autoxcuda] #2711239
10/30/19 01:15 PM
10/30/19 01:15 PM
dangina Offline
dangina  Offline
Mounted on the back! the rims were the year one rallye rims - The problem was the inside of the rim was rubbing against the top of the caliper...
