New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: New Best in the Duster!!!! w/vid
[Re: Dragula]
#2704266 10/06/1909:54 AM10/06/1909:54 AM
And all season...the valve covers never came off and like zero engine maintenance.......Very happy with this setup. If money allows, I will keep an eye out for a set of -1's or EZ325's...This engine is just one of those you fire it up and its wants to run, you can tell....Just nasty.
