Help me decide which clutch to use-Vote #270415
03/29/09 12:48 PM
03/29/09 12:48 PM
wisconsin
swifter Offline OP
swifter  Offline OP
wisconsin
Car 70 Duster with 06 5.7 hemi-Trans the ol A-833 should be in the 400hp range BUT I'm going to add a procharger set-up when i get over the cost of this resto so that being said it should be in the neighber hood of 500hp give me your feed back guys and gals Thanks Swifter
Centerforce df or Mcleod dual plate clutch
2007 Ram 2500 Cummins 2008 Dodge Nitro 1970 340 Valiant Duster
Re: Help me decide which clutch to use-Vote [Re: swifter] #270416
03/29/09 01:04 PM
03/29/09 01:04 PM
kewaskum wi
trend setters Offline
kewaskum wi
Mcleod RST then you don't have to replace it down the road.
Re: Help me decide which clutch to use-Vote [Re: trend setters] #270417
03/29/09 01:07 PM
03/29/09 01:07 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
What is the difference between the Mcleod RST and the Street Twin?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Help me decide which clutch to use-Vote [Re: 70sixpkrt] #270418
03/29/09 01:15 PM
03/29/09 01:15 PM
kewaskum wi
kewaskum wi
There is two different street twins. One is up to 800hp the other 1000 hp. go to
http://www.mcleodind.com/application_guide_pgs/RST_RXT_StreetTwin.html
Re: Help me decide which clutch to use-Vote [Re: trend setters] #270419
03/29/09 01:18 PM
03/29/09 01:18 PM
70sixpkrt Offline
70sixpkrt  Offline
Whats the difference between that one and this one?
http://www.mcleodind.com/application_guide_pgs/STREET_TWINS_mopar.html
4-speed
3:54 Dana
Re: Help me decide which clutch to use-Vote [Re: 70sixpkrt] #270420
03/29/09 01:32 PM
03/29/09 01:32 PM
kewaskum wi
kewaskum wi
go to new products 2009 guide it explains it there.
Looks like the street twin is for big hp, super chargers ect. up yo 1700 hp and the rst is for up to 900hp
Re: Help me decide which clutch to use-Vote [Re: trend setters] #270421
03/29/09 02:52 PM
03/29/09 02:52 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Have had excellent luck with center force. Have one behind each of my 2 340's. Hold up great. Friend had one behind a nasty 440. He was very happy also.
Re: Help me decide which clutch to use-Vote [Re: Posest] #270422
03/29/09 05:32 PM
03/29/09 05:32 PM
BC Canada
cudasam Offline
cudasam  Offline
BC Canada
I have had great luck with the centerforce behind a strong street 440. Flawless performance, however I have heard they can be sensitive to bellhousing centerline run-out. I dialed mine in and it was the best clutch I ever had.
