Fuel Rail for 1994 Dodge Caravan S.E., 3.3L, V6
#2704076
10/05/19 11:04 AM
10/05/19 11:04 AM
Posts: 1 Virginia
Aeromatefan82
Virginia
Hello,
I’m desperately looking for a part for my car. I own a unique vehicle called a UMC Aeromate. All Aeromates came stocked with Dodge Caravan engines. Mine is a 1994 Dodge Caravan S.E., 3.3L, V6.
Recently the fuel rail started leaking so I took it to my local shop. After digging around they couldn’t find a replacement and my local salvage yards had nothing. After an extensive search online I can see they were recalled, but I couldn’t find any parts other than the injectors. The original part number was 4554109. I believe a 4554108 is also compatible.
Does anyone possibly have a contact that might have a NOS 1994 Dodge Caravan S.E., 3.3L, V6, fuel rail, in stock? Also, does anyone know of another model fuel rail that might fit? I know a 93 Chrysler New Yorker is compatible, but couldn’t find one of those either.
Thank you for your time and help.
Re: Fuel Rail for 1994 Dodge Caravan S.E., 3.3L, V6
[Re: Aeromatefan82]
#2704162
10/05/19 07:50 PM
10/05/19 07:50 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
If that is the rail that leaks at the crossover on the left side, as you are sitting in the car and has the regulator on it on the right side, you can tap the ends out 1/4" pipe, and put fittings and a new line in. I used aeroquip fbm2616, 1/4 to #6 90 fittings and had them tig welded in. Make sure you get all the metal filings out of the rails with brushes like cleaning an engine. I found a used one but it leaked after installation too, once you move the o-rings they leak. No new ones around that I know of. A guy could use a later rail and rig up an external regulator, like the corvette one that is in the fuel filter. Guys have done this with straight hose fittings, blue gas pipe dope and fuel injection hose and fittings too.
