Re: Any PT Cruiser repair issues ?
[Re: topside]
#2703943
10/04/19 08:22 PM
10/04/19 08:22 PM
Posts: 1,177 People's Republic of Kali
70runner
The wife's 2001 still going strong. No radiator or pump issues. Last couple years, rad fan and motor mounts replaced. Motor mounts fairly common issue due to design. More recently, engine check light activity, mostly smog stuff. Very dependable 30+ mpg.
[Re: 70runner]
#2703977
10/04/19 10:44 PM
10/04/19 10:44 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
My wife has an 04 turbo car. Somewhere around 130K miles on it now. The timing belt was replaced at 100K as per recommendation, so while your in there, you replace the water pump and the timing belt tensioner.The original water pump didn't have any issues, but we are on pump #3 in about 30,000 miles. I can't work on this thing, my hands don't fit between the inner fenders and the timing belt end of the motor (passenger side). Changing the motor mounts is also a pita. The only other issue we have has been with front brake rotors cracking, we are on set #4 or 5. Our gas mileage runs about 24 mpg, tops, but we don't exactly drive it for the best mileage. Still, 24 is about the best its ever done. That said, my wife loves that car, so it will be here until she doesn't love it anymore. I've learned that lesson many years ago, if mama is happy with her car, you don't change it. Gene
[Re: dOc !]
#2704017
10/05/19 04:44 AM
10/05/19 04:44 AM
Posts: 20,627 in a cattle trailer down by th...
Guitar Jones
Heard through the grapevine that there are PITA repair issues like radiator and water pump R and R probs ? ... true ? Anything else ? Anything else? Yeah you'll never be able to repair your reputation as a geezer.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: dOc !]
#2704031
10/05/19 08:45 AM
10/05/19 08:45 AM
Posts: 1,331 Clinton, NJ
njmopar
Clinton, NJ
I just bought a 2010 for my daughter's first car. She loves the way they look and wanted one over anything else. Finding one around here that wasnt rusted underneath was a challenge. Found one with 23k miles and super clean.
Anyway, I did a lot of research and if you stay away from the turbo, this will remove one additional headache and space taker under the hood. You pretty much have to remove the grille and rad support to do anything on the front of the motor. Sounds worse than it is. To do the timing belt you need to evacuate the a/c. A/C compressor pressure sensors are common to leak on earlier ones. Typical lower control arm rust and bushing issues, similar to Neons. Separating the upper and lower plastic intake could result in a stripped thread insert. Those are the most common themes.
If you can find a 2010, this is the last year and had the most standard safety options, which was a plus for me with my daughter. Abs, 4 wheel disc, traction control, side airbags, EVIC cluster, were all standard. Hers even has a valid sirius radio account still (told her not to count on that working forever).
[Re: kenworth_goose]
#2704153
10/05/19 07:29 PM
10/05/19 07:29 PM
Posts: 1,890 Spahn Ranch
RMCHRGR
Spahn Ranch
Like said already, no room, everything is jammed in so tight you can barely get a hand in there. X2 If you have to do a timing belt or something on the front you definitely are taking the upper mount off and jacking the motor up, really no way to do it otherwise. Anything A/C related on them is a nightmare. Control arms and motor mounts go bad, the suspensions on those wear out pretty fast.
'71 Duster '17 Ram 1500
[Re: gtx6970]
#2704190
10/05/19 09:44 PM
10/05/19 09:44 PM
njmopar
Clinton, NJ
BUT my wife hated the one I had and thinks they are uglier than sin. so Odds are I'll never own another I never cared for them, but oddly enough the current teens are fond of them. All my daughters friends find it cute. One of the seniors has a convertible PT. Funny how that works.
[Re: RMCHRGR]
#2704284
10/06/19 10:58 AM
10/06/19 10:58 AM
Posts: 2,046 ky.
kenworth_goose
ky.
Like said already, no room, everything is jammed in so tight you can barely get a hand in there. X2 If you have to do a timing belt or something on the front you definitely are taking the upper mount off and jacking the motor up, really no way to do it otherwise. Anything A/C related on them is a nightmare. Control arms and motor mounts go bad, the suspensions on those wear out pretty fast. Like I said, remove the fans and radiator along with the upper mount bracket that bolted to the inner fender and a timing belt on these are a cake job. If you want to fight and cuss all day just leave the radiator and the mount bracket on.
