Help me ID a Barry Grant Carb #2703295
10/03/19 12:48 AM
10/03/19 12:48 AM
Laredo, Texas USA
hugo Offline OP
hugo  Offline OP
Laredo, Texas USA
I need help identifying a BG carb. Numbers I have 12r-9027b. On the side it also has these RT9377TE below that L711 below 45. On top were it has BG sign engraved it’s not clear but i has 277 and below that 2454.
Re: Help me ID a Barry Grant Carb [Re: hugo] #2703341
10/03/19 09:38 AM
10/03/19 09:38 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
9377 is an 1150 dominator in the Holley list
Re: Help me ID a Barry Grant Carb [Re: J_BODY] #2703378
10/03/19 11:49 AM
10/03/19 11:49 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I seem to recall the “RT” designation from BG meaning “reaction time”, which meant it was a drag carb.
I don’t recall what the TE suffix was though.
We had a customer who bought one of their high end “pro stock” type prepped 9377’s.
It was $1400 in about 1997.
It had very little actual modifications done to it........ which I discovered after completely taking it apart(boosters out, idle tubes removed, etc)....... after the motor it was on torched 3 pistons.
After correcting the manufacturing defects(which were the cause of the burned pistons), it ran okay........ but not really much different than an ootb 9377 that had been properly tuned.
They did make the venturi in the main body very shiny though.
Re: Help me ID a Barry Grant Carb [Re: fast68plymouth] #2703391
10/03/19 12:42 PM
10/03/19 12:42 PM
Laredo, Texas USA
hugo Offline OP
hugo  Offline OP
Laredo, Texas USA
This carb was bought back in the mid 1990's probably around 1996. It has worked very well for us. I just don't know what it is since my father bought it and does not remember what it is. He does remember he bought it for a 540 indy engine he built back them and it worked.
I am planning a new build a 540 or 557 and I want to know what it is so I can use it or get something more suitable for my combo.
Thanks!
Re: Help me ID a Barry Grant Carb [Re: fast68plymouth] #2703405
10/03/19 01:28 PM
10/03/19 01:28 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Too Expensive
Re: Help me ID a Barry Grant Carb [Re: BradH] #2703445
10/03/19 03:24 PM
10/03/19 03:24 PM
So. Burlington, Vt.
So. Burlington, Vt.
If it worked well on a 540 previously, no reason to think it wouldn’t still.
I found an ad for someone selling one.
Their description:
Review (mpn: rt9377te for sale) RT9377TE Barry Grant Dominator Holley 1150 9377
It cost 1,375. It ran flawlessly for me and I kept through the years, using on several different bb chevy drag race pro-street engines. It was their most modified dominator for single carb application is a drag race reaction time top eliminator gas. Unfortunately I think I'm done and am offering it for sale.
It has been in warm dry storage since. I saved it when sold my last car in hope to use on next project. It was bgs best 1x4 4500 at the time. History: I bought this carb new in 1995 for a drag race big block chevy.
I'm starting the auction at a low price with no reserve. The bg part number is rt9377te. Barry Grant dominator - this is a modified holley cfm gas. After its last use a few years ago, I cleaned it thoroughly and installed new gaskets.
part: rt9377te prices
Specifications rt9377te:
manufacturer part number: RT9377TE
Re: Help me ID a Barry Grant Carb [Re: fast68plymouth] #2703642
10/04/19 12:08 AM
10/04/19 12:08 AM
Laredo, Texas USA
hugo Offline OP
hugo  Offline OP
Laredo, Texas USA
Their description:
Thanks fast68plymouth I appreciated the info has been very helpful.
