Re: Pictures Showing Under Dash Install of Aftermarket Radio
[Re: topside]
#2702547
10/01/19 10:22 AM
10/01/19 10:22 AM
Posts: 211 Halifax, VA.
moparjack44
Halifax, VA.
Yeah, the FM converter deal...I'd forgotten about those, had one back in the day. I think it was 1310 you tuned to. Worked pretty well, though not quite the concert hall experience... Yep, ran one on my 69 SuperBee for many years. Never a problem.
K.I.S.S.
[Re: VITC_GTX]
#2703147
10/02/19 05:40 PM
10/02/19 05:40 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I have an under dash f.m. converter as mentioned above, sitting on the shelf. When I was using it, I just used a flat chunk of sheet metal and bent it to fit the tuner. Dropped a couple screws through the bottom of the dash and that was that. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Uses the stock a.m. radio for an amp so not the greatest sound as others have said. Sure did dig not being stuck with am. ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) Had this one in my 68 Coronete 500 and the 68 Fury for many many years.
I have mechanical Aptitude. I can screw up anything.
