molar crank #2702269
09/30/19 01:47 PM
09/30/19 01:47 PM
Iowa
coronetville Offline OP
Iowa
looking at a rotating ass. that has a molar crank [bb 4.5oo] good or bad?
Re: molar crank [Re: coronetville] #2702275
09/30/19 02:08 PM
09/30/19 02:08 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I haven't seen a kit with Molnar crank and rods, but I found my best deal on Molnar components with Don at 4seconds flat. I bought a set of Icons for$500. Not a bad piston for the price.
Re: molar crank [Re: mopar dave] #2702280
09/30/19 02:23 PM
09/30/19 02:23 PM
western pennsylvania
b1dartsport Online content
b1dartsport  Online Content
Used Molnar 4.250 crank and Rods in a Hemi a couple of yrs ago. They measured as good or better than the Callies setup in my Small Block stroker. Spoke to Molnar himself on the phone before ordering and after he explained his Qualiity Control measures I was impressed. We probably talked for 45 minutes, where do you find that type of care for customers in todays World. The Hemi is a beast.
Re: molar crank [Re: b1dartsport] #2702281
09/30/19 02:25 PM
09/30/19 02:25 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I did the same. He gave me all the time I wanted. Great guy, great company.
Re: molar crank [Re: mopar dave] #2702311
09/30/19 04:04 PM
09/30/19 04:04 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Have a 4.25" in my street/strip car motor that made 713/709 hp/torque.
Had a discussion with Tony Bischoff on what to use in my new build for the race car. Went with the 4.5" Molnar crank and this motor will be 1000 hp. The Callies crank was a potential option for about 3x the money and delivery was questionable and it had to be bought through Barton so went with the Molnar. Tony is comfortable with the decision.
Re: molar crank [Re: markz528] #2702316
09/30/19 04:32 PM
09/30/19 04:32 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Been running a 4.5" Molnar crank in the 540 for a few years now. Probably 850 horse. So far so good. No complaints.
Re: molar crank [Re: mopar dave] #2702549
10/01/19 10:24 AM
10/01/19 10:24 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
My experience as well. In my opinion one of the best companies in racing. Give Tom a call and tell him what you want to do. Have reciprocating weights and he will tell you what he has that will work for you. He does not care if you buy it from him or one of his dealers.
Re: molar crank [Re: 340Cuda] #2702660
10/01/19 03:51 PM
10/01/19 03:51 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My experience with Tom was great. He is very helpful. The parts were near perfect on weight. Machining was good as well. Parts balanced without Mallory metal. 4.500crank, 7.100/2.200/.990 rods. Over 300 passes on the rods, nearly 200 on the crank without issue. 2222 bobweight. Max rpm 7500.
Doug
Re: molar crank [Re: dvw] #2702781
10/01/19 10:18 PM
10/01/19 10:18 PM
Iowa
Iowa
thanks everyone, sounds like iam barking up the right tree for a change
Re: molar crank [Re: cl440] #2702893
10/02/19 08:44 AM
10/02/19 08:44 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
I missed typed. We run a 4.25 Molnar crank with a 4.5" bore in our 540. Still very happy with the Molnar crank. I believe at the time Molnar was the only (other than high dollar or custom) crank manufacturer that had true chevy width rod journals with RB mains
Re: molar crank [Re: coronetville] #2702904
10/02/19 09:15 AM
10/02/19 09:15 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Molnar, Molnar, Molnar...
Re: molar crank [Re: BradH] #2702953
10/02/19 10:27 AM
10/02/19 10:27 AM
USA
hudsonhornet7x Offline
USA
Is this a vote for Molnar or against? Being honest, I could read this either way.
Re: molar crank [Re: hudsonhornet7x] #2702962
10/02/19 10:37 AM
10/02/19 10:37 AM
BradH Offline
BradH  Offline
Not a vote, a reminder on the proper spelling.
And, FWIW, I've heard only positive things about Molnar's products.
Re: molar crank [Re: BradH] #2702985
10/02/19 11:29 AM
10/02/19 11:29 AM
AndyF Offline
AndyF  Offline
I like the Molnar stuff as long as he has it in stock. You have to use the correct main seal with the Molnar crank. If Molnar doesn't have any cranks in stock then my next choice is SCAT. SCAT typically wants a different rear main seal than Molnar but you have to inspect first since it isn't always the same. K1 also makes good cranks but they don't have a super big selection. Nice thing about K1 is that they are owned by the same folks who own JE so if you are a dealer you can sometimes bundle up a K1 crank and rods with JE pistons and get a good price.
Re: molar crank [Re: AndyF] #2703043
10/02/19 01:26 PM
10/02/19 01:26 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Not sure I used the correct seal with mine, but I do get a single drip on the ground once in awhile. I used the Superformance seal. What is the correct seal for next time I do this?
Re: molar crank [Re: AndyF] #2703076
10/02/19 03:01 PM
10/02/19 03:01 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Originally Posted by AndyF
You have to use the correct main seal with the Molnar crank. SCAT typically wants a different rear main seal than Molnar but you have to inspect first since it isn't always the same.
What is the difference in the seal? Why would one crank use any different seal than another? Do you have seal part numbers?
Doug
Re: molar crank [Re: dvw] #2703096
10/02/19 03:49 PM
10/02/19 03:49 PM
AndyF Offline
AndyF  Offline
Some cranks are knurled and some are smooth. It seems to vary.
Re: molar crank [Re: AndyF] #2703151
10/02/19 05:55 PM
10/02/19 05:55 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
So whats your choice of seals?
Doug
Re: molar crank [Re: dvw] #2703152
10/02/19 06:03 PM
10/02/19 06:03 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Doug
Lip or rope
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
