A833 TRANS ID HELP #270267
03/29/09 11:30 AM
03/29/09 11:30 AM
North Bay On.
mrdodge69 Offline OP
super gas
super gas
North Bay On.
Need Help trying to ID a A833 trans. Casting on the side of the case is C99129-H
Can anyone help with what this is out of or what it fits?
Thanks.
Re: A833 TRANS ID HELP [Re: mrdodge69] #270268
03/29/09 11:52 AM
03/29/09 11:52 AM
hemisurfer Offline
hemisurfer  Offline
I think it would be easier and more useful to identify the type of tail shaft you have, the type of side cover, and the size of the input spline 23 or 18.
From there you will be able to ID what it fits and what years.... use this as a guide.
http://www.yearone.com/infocenter.asp?se...fo/trans_id.asp
Chris
Re: A833 TRANS ID HELP [Re: mrdodge69] #270269
03/29/09 12:30 PM
03/29/09 12:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That casting number is the same on all cast iron 833 manicases , TOTALLY USELESS in trying to identify the trans .
Is it a 23 spline or 18 spline ?
Does the tailshaft have 1 shifter mounting boss or 2 ?
If 2 it's a B/E body trans.
If 1 is the mount in front of the trans mount or behind it ?
If in front it's a B body trans , behind A body trans .
Re: A833 TRANS ID HELP [Re: JohnRR] #270270
03/29/09 12:33 PM
03/29/09 12:33 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
List all the information on the VIN pad or a clear photo of it as well.
Re: A833 TRANS ID HELP [Re: Alaskan_TA] #270271
03/29/09 12:54 PM
03/29/09 12:54 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Yep, a pic like this would be most helpful:
Re: A833 TRANS ID HELP [Re: In_The_Pink] #270272
03/29/09 01:04 PM
03/29/09 01:04 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Here are two of the possible configurations
