Adding 15 inch rims to E-body #2702671
10/01/19 04:21 PM
10/01/19 04:21 PM
3
340clone Offline OP
340clone  Offline OP
I am contemplating adding a set of factory 15 inch rallye rims to my '71 Challenger, which currently has 14 inch rallyes. Is there any reason that the 15 inch wouldn't fit? Fenders, etc?
Thanks!
Re: Adding 15 inch rims to E-body [Re: 340clone] #2702672
10/01/19 04:27 PM
10/01/19 04:27 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
None at all unless you go with very wide 15's, the fenders & quarters are the same.
You may need to change your speedometer pinion gear so your speedometer reads correctly though. The overall tire diameter on the rear tires can change that.
Re: Adding 15 inch rims to E-body [Re: Alaskan_TA] #2702806
10/02/19 12:54 AM
10/02/19 12:54 AM
3
340clone Offline OP
340clone  Offline OP
Thank you! That is good to know. IIRC, the tire height on the 14 inch is 24.5 inches, and the 15 inch is 26 inches. Hopefully my current torsion bar adjustment will handle the height, or else I'll need an adjustment/alignment. Hopefully the inch an a half won't affect it...
Re: Adding 15 inch rims to E-body [Re: Alaskan_TA] #2702819
10/02/19 07:00 AM
10/02/19 07:00 AM
greenfield, ind.
P
PLMCRZY Offline
PLMCRZY  Offline
P
greenfield, ind.
the wheels will fit, but there is a difference in fenders. just sayin.
the (Jan./72) 1970-71 Parts Catalog shows (3 sets of 70-71 fenders):
70 J, except w/F60x15 tire 3419 878/879 - '70 Parts Catalog "except 6.00 x 15 tires"
70 & 71 J, w/F60x15 tire 3579 380/381 - '70 Parts Catalog "w/6.00 x 15 tires"
J, Trans Am, w/F60x14 tire 3579 624/625
Re: Adding 15 inch rims to E-body [Re: 340clone] #2702971
10/02/19 11:05 AM
10/02/19 11:05 AM
central il.
second 70 Offline
second 70  Offline
central il.
26" tall on 15" rims will fit easy. I now have 28 on the front and back of my cuda.
Here's a picture with factory rallye's 15" and F60-15 and the new larger tires.
!Bg-e1Sg!2k~$(KGrHqEOKj0Er)0G,n(BBLHJ(n81+!~~_3.jpg60712735_10211901006555675_4226967204811243520_o.jpg
Re: Adding 15 inch rims to E-body [Re: 340clone] #2704451
10/06/19 10:12 PM
10/06/19 10:12 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
275-60/15 will fit on the rear, and 235-60/15 will fit just fine. I have used those tire sizes on several Challengers with 15" Rallyes, and had no problems.
Re: Adding 15 inch rims to E-body [Re: JDMopar] #2704726
10/07/19 09:53 PM
10/07/19 09:53 PM
God's Country Maryland
GODSCOUNTRY340 Offline
31x10.50-15, no rubbing.
