Thanks everyone. I checked Vintage Air website, they have a very good online Tech, that was helpful also. I will check to sure upon original install, I did the correct order. Will be going on another long trip on Oct 11th to car show and drags at Dunn NC. I will let you know how/if the AC works OK..
Thanks,
Jack
Did not get to make the trip to Dunn. I did check and found AC was low in freon. I filled it up, but the weather has made a dramatic drop in temperature here and have not needed to use the AC. Maybe next year
. Thanks for everyones input.
Jack
