Plug wire resistance #2702361
09/30/19 07:30 PM
09/30/19 07:30 PM
Kentucky
dfsmopars Offline OP
Kentucky
MSD 8.5 mm wires. Checking resistance across studs in dist to plug connector. Getting 75 ohms to 112 ohms. Five wires are 104 and above. Three wires are 82 and below. Does that seem within reason?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Plug wire resistance [Re: dfsmopars] #2702380
09/30/19 08:07 PM
09/30/19 08:07 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Not sure what they advertise, interesting that yours are differing; does length play into that? heat?
For non-resto/race stuff I think Taylor has among the lowest resistance.
Re: Plug wire resistance [Re: topside] #2702389
09/30/19 08:18 PM
09/30/19 08:18 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Plug wire resistance [Re: dfsmopars] #2702427
09/30/19 09:22 PM
09/30/19 09:22 PM
Kentucky
Kentucky
Oh. I didn’t think of length of wire. That probably explains.
I have bigger problems is why I’m looking. #8 intake push rod is bent because it was rubbed nearly in two pieces and bent. When I looked closely most of the are rubbed badly on the guide plate. This is a 5.9 Magnum with a Hughes roller cam and rockers with Indy X heads.
