ST-437 Swedge Cutter
#2702292
09/30/19 03:18 PM
09/30/19 03:18 PM
Posts: 10,694 North Dakota
6PakBee
North Dakota
I've been looking for a wheel stud swedge cutter for 7/16" studs. The Goodson ST-437 would have worked but they no longer offer it. For $1060 they'll make one for me but I think I'll pass on that idea. Does anyone know of another supplier? I've looked for a couple days and can't find anything comparable. Thanks!
Re: ST-437 Swedge Cutter
[Re: 6PakBee]
#2702303
09/30/19 03:41 PM
09/30/19 03:41 PM
Posts: 25,720 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A 9/16" hole saw with the arbor removed?
[Re: 6PakBee]
#2702309
09/30/19 03:54 PM
09/30/19 03:54 PM
Posts: 4,269 Morrow, OH
markz528
Morrow, OH
I've been looking for a wheel stud swedge cutter for 7/16" studs. The Goodson ST-437 would have worked but they no longer offer it. For $1060 they'll make one for me but I think I'll pass on that idea. Does anyone know of another supplier? I've looked for a couple days and can't find anything comparable. Thanks! I promised to make some 1/2 inch cutters for some folks and would not be a problem to make them 7/16. I could make one for you next week. Mine are great if you only use them sporadically. I make them from hardened drill rod. I have not had the incentive to make a carbide tipped cutter.
[Re: John_Kunkel]
#2702310
09/30/19 04:00 PM
09/30/19 04:00 PM
Posts: 29,650 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
A 9/16" hole saw with the arbor removed? Please tell us you are not a machinist?
[Re: markz528]
#2702312
09/30/19 04:07 PM
09/30/19 04:07 PM
Posts: 553 DE
Ply72rr
DE
I've been looking for a wheel stud swedge cutter for 7/16" studs. The Goodson ST-437 would have worked but they no longer offer it. For $1060 they'll make one for me but I think I'll pass on that idea. Does anyone know of another supplier? I've looked for a couple days and can't find anything comparable. Thanks! I promised to make some 1/2 inch cutters for some folks and would not be a problem to make them 7/16. I could make one for you next week. Mine are great if you only use them sporadically. I make them from hardened drill rod. I have not had the incentive to make a carbide tipped cutter. Marks528 How much do you charge for these?
[Re: Ply72rr]
#2702322
09/30/19 05:24 PM
09/30/19 05:24 PM
markz528
Morrow, OH
I've been looking for a wheel stud swedge cutter for 7/16" studs. The Goodson ST-437 would have worked but they no longer offer it. For $1060 they'll make one for me but I think I'll pass on that idea. Does anyone know of another supplier? I've looked for a couple days and can't find anything comparable. Thanks! I promised to make some 1/2 inch cutters for some folks and would not be a problem to make them 7/16. I could make one for you next week. Mine are great if you only use them sporadically. I make them from hardened drill rod. I have not had the incentive to make a carbide tipped cutter. Marks528 How much do you charge for these? I make them for fun not profit. If you are interested send me a PM.
[Re: markz528]
#2702337
09/30/19 06:17 PM
09/30/19 06:17 PM
John_Kunkel
Rio Linda, CA
Got a pic?
[Re: John_Kunkel]
#2702343
09/30/19 06:40 PM
09/30/19 06:40 PM
markz528
Morrow, OH
Got a pic? Not home till Wednesday - will post one then.
[Re: markz528]
#2702594
10/01/19 12:30 PM
10/01/19 12:30 PM
6PakBee
North Dakota
Got a pic? Not home till Wednesday - will post one then. Super! I'll wait for the picture but I am interested.
[Re: 6PakBee]
#2702797
10/01/19 11:39 PM
10/01/19 11:39 PM
markz528
Morrow, OH
They would look something like this but with a reduced 1/2" shank to fit in a 1/2" chuck. I would make sure they fit correctly over a 1/2" or 7/16" stud. I have used these before and they worked very well.
[Re: gzig5]
#2711987
11/01/19 10:00 PM
11/01/19 10:00 PM
markz528
Morrow, OH
Well I'm a Dumb-$^#! My prototype 1/2" cutter is a left hand cutter! LOL! But the good news is it cuts great!
So it will take a bit to correct my drawing and programs............
[Re: moparx]
#2712281
11/02/19 11:13 PM
11/02/19 11:13 PM
markz528
Morrow, OH
I recovered pretty good. Roughed out (7) 7/16" and (9) 1/2" cutters today. Need to cut the shanks, harden and grind before they are done.
[Re: 6PakBee]
#2913739
04/23/21 02:47 AM
04/23/21 02:47 AM
Posts: 1,653 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
I've been looking for a wheel stud swedge cutter for 7/16" studs. The Goodson ST-437 would have worked but they no longer offer it. For $1060 they'll make one for me but I think I'll pass on that idea. Does anyone know of another supplier? I've looked for a couple days and can't find anything comparable. Thanks! I'm using the Goodson ST-437 that I was lucky enough to buy 6 months before the OP posted. Maybe the last one? Can someone who has cut the swages off their front brake drum lug studs please tell me if I have gone deep enough to press out the studs? I went just deep enough for the tool to fully clean up both the lug studs and the drum. But I'm wondering if maybe the stud is swaged or mushroomed deeper than the top surface of the drum? How much below the top surface of the drum should I go? Should I replace the drum after using this tool? Before I bought the tool and not knowing the studs were swaged, I pressed on a stud with my 12-ton press against a socket around the stud head and it warped the drum. I'm trying to avoid repeating that fiasco if the drum is salvageable after de-swaging.
[Re: kentj340]
#2913857
04/23/21 11:57 AM
04/23/21 11:57 AM
Posts: 19,305 north of coder
moparx
i think you may be good where you are at. one way to find out. lightly tap on the broken stud, "lightly" being a subjective term, just not 12 tons of force. if it moves, you are good to go. there is some press fit on the drum bore to hub od, but i don't know, or remember, how much that is.
