70RR Clutch issues.....?
#2702048
09/29/19 06:26 PM
09/29/19 06:26 PM
Posts: 2,087 New Mexico
JMCFAN
New Mexico
Complete new build...and I am not a 4sp guy...
initial startup car would not go into gear when running. Initial though was....dummy put clutch in backwards... but no...it was in right... but I am getting contact on clutch springs and forks... ideas...??? what did I goof up....??
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Re: 70RR Clutch issues.....?
[Re: fourgearsavoy]
#2702077
09/29/19 07:56 PM
09/29/19 07:56 PM
JMCFAN
New Mexico
My suspicion is the Zbar is incorrect.... how can I tell?? So many variations....
[Re: JMCFAN]
#2702256
09/30/19 01:15 PM
09/30/19 01:15 PM
Posts: 25,729 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I just went through this with all the correct linkage parts, turned out to be the clutch itself i.e. pressure plate or disc too thick. Wound up making a clutch pedal stop.
[Re: John_Kunkel]
#2702262
09/30/19 01:31 PM
09/30/19 01:31 PM
JMCFAN
New Mexico
I just went through this with all the correct linkage parts, turned out to be the clutch itself i.e. pressure plate or disc too thick. Wound up making a clutch pedal stop. Can you share how..?
[Re: JMCFAN]
#2702284
09/30/19 02:27 PM
09/30/19 02:27 PM
Posts: 480 Lakewood, WA
rick@laysons
Lakewood, WA
I had the very same issue awhile ago with a 70 RR that I had.... Turns out I had the in-correct pressure plate to flywheel attaching screws. If using a 10.95" "scalloped" pressure plate, you MUST use the correct pressure plate-to-flywheel attaching bolts. If you don't, the edges of the disc interferes with the heads of the attaching bolts and it seems as tho the clutch will not dis-engage when engine is running, but you are able to shift thru the gears when engine is shut off. This cost me two days of my life I'll never get back.....LOL! See this link...... http://www.brewersperformance.com/proddetail.php?prod=BP1500Hope this helps..... Rick
[Re: JMCFAN]
#2702304
09/30/19 03:43 PM
09/30/19 03:43 PM
John_Kunkel
Rio Linda, CA
