Re: Better master cylinder options?
[Re: poorboy]
#2701896
09/29/19 05:06 AM
09/29/19 05:06 AM
Posts: 5,764 ohio
ruderunner
ohio
Fyi, on trucks in that era, they used 2 master cylinders, light trucks got the aluminum and plastic cylinder, higher gvw got the big one piece cast iron one.
Op, you sure you're not over filling the master? Should be a quarter to 38 inch from top.
Angry white pureblood male
[Re: dusterguy]
#2702107
09/29/19 10:01 PM
09/29/19 10:01 PM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
my '91 W250 Cummins had the big cast master, seems to be a common problem with that type leaking, mine sure did.
1981 Dodge D150 360 auto
[Re: basketcase]
#2702157
09/30/19 05:57 AM
09/30/19 05:57 AM
Posts: 5,764 ohio
ruderunner
ohio
Ok, ill bet you have the same problem i do. Im not leaking fluid anywhere but, its transferring from one reservoir to the other.
I cut a small notch between reservoirs, whizzer wheel about half inch deep in the divider.
Oddly my 92 is the only one that has ever done it and does it with different master cylinders. I suspect its bypassing through the safety switch.
[Re: dusterguy]
#2703183
10/02/19 07:45 PM
10/02/19 07:45 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Mine is the huge cast iron unit. The master cylinder will run itself dry no matter where I keep the fluid level at. No leaks in the rest of the system. Are you actually losing fluid with no visible leaks? If it's running itself dry, it is going some where. It might be going into the booster from the back of the cylinder. Not good. Might want to take a peak.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#2703266
10/02/19 10:37 PM
10/02/19 10:37 PM
Posts: 1,565 tennessee
pushbutton
tennessee
[quote=dusterguy]Mine is the huge cast iron unit. The master cylinder will run itself dry no matter where I keep the fluid level at. No leaks in the rest of the system. Are you actually losing fluid with no visible leaks? If it's running itself dry, it is going some where. It might be going into the booster from the back of the cylinder. Not good. Might want to take a peak. [/quote I had one doing that and it was leaking out the back down inside the firewall,like was said it's going somewhere.
[Re: dusterguy]
#2703720
10/04/19 09:12 AM
10/04/19 09:12 AM
pushbutton
tennessee
It leaks all around the seal between the cap and cast iron body. Frame rail on that side is constantly wet. Sorry,I thought you didn't know where it was leaking.
