71 wing location #2700545
09/24/19 06:11 PM
09/24/19 06:11 PM
iowa
copchaser Offline OP
iowa
I'm looking for the measurements where to drill the holes on a 71 Superbee for the Gullwing. Thanks.
Re: 71 wing location [Re: copchaser] #2700630
09/24/19 11:17 PM
09/24/19 11:17 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If your asking for measurements it's safe to assume you don't have the correct trunk lid? if the car is still in build status, find the correct lid, otherwise it's not going to look pretty underneath
Re: 71 wing location [Re: DAYCLONA] #2700738
09/25/19 11:06 AM
09/25/19 11:06 AM
iowa
iowa
I've got the correct deck lid. Just needing the measurements for the hole locations.
Re: 71 wing location [Re: copchaser] #2700745
09/25/19 11:25 AM
09/25/19 11:25 AM
CrazyD Offline
CrazyD  Offline
Have not verified attached information, just passing it along...
1971 Charger Wing Location
Re: 71 wing location [Re: CrazyD] #2700756
09/25/19 11:58 AM
09/25/19 11:58 AM
iowa
iowa
Thank you!!!!
Re: 71 wing location [Re: copchaser] #2700758
09/25/19 12:06 PM
09/25/19 12:06 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I opened that link, looked at AKcharger's post and somehow lost a half hour. I just couldn't look away.
Re: 71 wing location [Re: burdar] #2701140
09/26/19 01:54 PM
09/26/19 01:54 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
I had all the schematics and guides as well, then i just ended up taking a deep breath and installed the black brackets and used them as a guide to do like a center punch. Came out decently enough for me.
Good luck with yours. I also stressed when doing the hood pins. smile
