Fan for 360 Crate Motor #2700255
09/23/19 08:15 PM
09/23/19 08:15 PM
L.A., CA
P
plysat Offline OP
plysat  Offline OP
P
L.A., CA
I lazily had someone else replace my water pump a while ago, and just now noticed that the fan was replaced as well. Also noticed that there is, literally, now only about 3/16" clearance between the blades and the top radiator hose. :-o so.. what size (non-clutch) fan do I need, and any clue where to find one? Thanks!
EDIT: If it matters, this is in a '68 Satellite, and was using the OE fan that had been on the 318 that I replaced with the 360.
Re: Fan for 360 Crate Motor [Re: plysat] #2700318
09/24/19 01:41 AM
09/24/19 01:41 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
May I ask why you do not want to run a clutch fan? The MP viscous clutch fan is a good unit.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Fan for 360 Crate Motor [Re: mopardude318] #2700473
09/24/19 02:06 PM
09/24/19 02:06 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
If memory serves, the original fans were 17-18" diameter depending on application.
Not sure what they put on there, but it also sounds like you don't have a fan shroud ?
Re: Fan for 360 Crate Motor [Re: mopardude318] #2700490
09/24/19 03:15 PM
09/24/19 03:15 PM
L.A., CA
P
plysat Offline OP
plysat  Offline OP
P
L.A., CA
RE: fan clutch... No particular reason, it just never had one... Is it worth getting? Any issues replacing it?
Re: Fan for 360 Crate Motor [Re: topside] #2700491
09/24/19 03:17 PM
09/24/19 03:17 PM
L.A., CA
P
plysat Offline OP
plysat  Offline OP
P
L.A., CA
Thanks. No fan shroud... never had one even with the original 318...
