6.4 block questions #2699322
09/20/19 06:26 PM
09/20/19 06:26 PM
New Smyrna Beach FL
scottb Offline OP
scottb  Offline OP
New Smyrna Beach FL
How much stronger is a 6.4 truck block then a 6.4 car block I know the truck block is like a hellcat block will a 6.4 car block hold up to a 1k hp motor
Re: 6.4 block questions [Re: scottb] #2699751
09/22/19 09:52 AM
09/22/19 09:52 AM
Northern California
B5 Classic Offline
B5 Classic  Offline
Northern California
The 392 BGE truck block IS a Hellcat block, or vice versa, except for color. The 392 SRT block is a pretty good block, but I don't know that I'd build it to 1,000 hp while knowing there's a stronger block available. FCA has never really said how much stronger the BGE block is, they've just provided bits of information for mag and tech articles, stating it's been strengthened here and there.
I have a brand new Hellcat block (the orange one) I'm probably going to sell. I bought it to build, but then bought a Hellcrate engine when they came out. Really don't have use for the bare block now.
Re: 6.4 block questions [Re: B5 Classic] #2699788
09/22/19 11:03 AM
09/22/19 11:03 AM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
After 2016 they are the same block,(different colors) the 6.4 blocks have a thinner cylinder casting and they don't have the ribs joining the bottom of the cylinders together in the water jacket.
I don't know about the 6.4 blocks but I've seen BGEs go well in to the high 1400hp. My Hennessy Demon is just over 1100 at the wheels and has about 6500 mile on the build.
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: 6.4 block questions [Re: Ray408G3Hemi] #2699799
09/22/19 11:24 AM
09/22/19 11:24 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
One BIG difference between the Hellcat and BGE block is the water jackets. The BGE water jackets are about 11/2" shorter. There is alot of solid cast iron in the bottom end of that block. Add billet main caps and it will take alot.
Re: 6.4 block questions [Re: fbs63] #2699989
09/22/19 10:35 PM
09/22/19 10:35 PM
Northern California
B5 Classic Offline
B5 Classic  Offline
Northern California
Wondering, have you personally seen and compared the difference between the black BGE block (truck 6.4) and the orange BGE block (Hellcat) ? I keep reading everywhere that they both have the shorter water jackets. If you have a black BGE block, I have an orange one. Maybe we can compare some measurements...
Re: 6.4 block questions [Re: fbs63] #2700046
09/23/19 08:49 AM
09/23/19 08:49 AM
USA
hudsonhornet7x Offline
USA
I was under the impression that any block with the BGE cast into it was the same. So there are different water jackets in BGE blocks?
Re: 6.4 block questions [Re: hudsonhornet7x] #2700060
09/23/19 09:30 AM
09/23/19 09:30 AM
Springtown Pa
Springtown Pa
No ,..... the 6.4(11-17) is different from the BGE(14+) see the bumped BGE thread
1996 Viper GTS
Re: 6.4 block questions [Re: Ray408G3Hemi] #2700150
09/23/19 02:33 PM
09/23/19 02:33 PM
USA
USA
I agree with you. The statement though made it sound like the Hellcat and the BGE were different blocks. My Hellcat block has BGE cast right into it.
Re: 6.4 block questions [Re: hudsonhornet7x] #2700292
09/23/19 10:22 PM
09/23/19 10:22 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I had an orange Bge block here for a build and the water jackets were considerably shorter. Didn't take exact measurements. I remember reading when the Hellcat engine first came out that the water jackets were LONGER in the block to help cooling because of the boost.
Re: 6.4 block questions [Re: fbs63] #2700458
09/24/19 01:11 PM
09/24/19 01:11 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Just checked the BGE block I have on my shop floor right now is 1.5 inches less water jacket depth than an early or late 5.7 blocks I also have sitting here. Also the bores are siamesed about 1/2 the distance up VS the 5.7 bores not touching each other the entire length of those longer water jackets.
Re: 6.4 block questions [Re: HotRodDave] #2700460
09/24/19 01:15 PM
09/24/19 01:15 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
BGE is for big gas engine, they did not just say 6.4 as it would be inacurate when used as a hellcat and visa versa so they just called it BGE. They could have done like chevy did with the 4.8 and 5.3 ID on all 4.8 and 5.3 blocks. The only confusing thing for me is what I am going to build this BGE thing for, kinda hoping to find me a nice 09+ 4 door 4x4 1500 truck.
Re: 6.4 block questions [Re: HotRodDave] #2700674
09/25/19 07:46 AM
09/25/19 07:46 AM
Springtown Pa
Springtown Pa
same with the 6.1s and the 5037471BF 6.4 block the cylinders don't touch at the bottom,
1996 Viper GTS
