Complete axle housing choices #2697556
09/14/19 06:15 PM
09/14/19 06:15 PM
templeton,ma
coro500net Offline OP
templeton,ma
What is the way to go on complete axle housing?
I’m building a 69 Valiant Street car with a 470 bb,looking to buy a strong rear end for it.
Have a 8 3/4 housing but no chuck or axles.
What are the best choices,Dana,8 3/4, 9 inch?
Not a race car but want something that will last.
What are my options?
As always cost is a concern.
Re: Complete axle housing choices [Re: coro500net] #2697558
09/14/19 06:21 PM
09/14/19 06:21 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
A cool article by Dr. Diff with pinion comparisons at www.doctordiff.com/blog/tech-info/rearend-pinion-comparison/
The Ford 9" is a weak link.
Re: Complete axle housing choices [Re: coro500net] #2697576
09/14/19 07:30 PM
09/14/19 07:30 PM
You might consider haveing Moser cut down some C body or truck 8&3/4 axles to A body length. they'd be BBP which I am assuming you want. then a 742 clutch sure grip pig in the ratio you want.
Re: Complete axle housing choices [Re: RapidRobert] #2697763
09/15/19 01:30 PM
09/15/19 01:30 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
At 300 to 400 dollars for new axles ( often with new bearings and wheels studs installed ) I wouldn't for a second consider cutting and resplining stock axles. By the time you procure the used axles and pay shipping both ways, you haven't saved much. If starting from scratch, you may be able to build a Dana 60 cheaper than a 8.75. Twenty years ago, it wasn't hard to find a used 8.75 center section with a good sure grip and 3 series gears for a reasonable price. Not so easy nowdays. 60 truck rears can be found cheap. It's possible that it already has the ratio you want. They mostly came with 3.55, 3.73 and 4.10. Housing narrowing if you cant do it yourself may cost $200. Axles, spools, diffs, etc about same price as 8.75. if your 8.75 housing is an A body width you could probably get $ 300 or so out of it.
Re: Complete axle housing choices [Re: forphorty] #2697795
09/15/19 03:50 PM
09/15/19 03:50 PM
templeton,ma
templeton,ma
Been checking out the Dana S60 but once you do all your specs the price goes up quickly.
I know a new complete rear is going to cost a good amount, just thought there may be a inexpensive alternative.
Looking around at all the rear axle builders it looks like you have to pay to play. Shipping is a big cost also.
Re: Complete axle housing choices [Re: coro500net] #2697806
09/15/19 04:28 PM
09/15/19 04:28 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Dr Diff sells the S60, had the best price & shipping for mine.
Re: Complete axle housing choices [Re: CSK] #2697809
09/15/19 04:35 PM
09/15/19 04:35 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
This is the most popular version:
Bolt in S-60 Dana 60 with choice of ratio, 1350 yoke, 35 spline axles and Strange-Trac differential upgrade. Fully street-able and good to 1000 hp. $2590
Shipping runs approximately $235 to a freight dock or business address.
Re: Complete axle housing choices [Re: DoctorDiff] #2699966
09/22/19 09:26 PM
09/22/19 09:26 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
Yep, I went with Strange S60 with a Detroit locker, 3.73 gears, 35 spline axles, and wilwood disc brakes. I bought it directly through Strange about 10 years ago, before I knew about Cass at DoctorDiff
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
