New Petcock #2699870
09/22/19 02:05 PM
09/22/19 02:05 PM
BlueRacer69 Offline OP
Does it need some sort of sealer on it before being screwed into the radiator? If so, what? Thank you. wrench
Re: New Petcock [Re: BlueRacer69] #2699872
09/22/19 02:08 PM
09/22/19 02:08 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Just put a new one on my 51 Cambridge. No sealant needed.
Re: New Petcock [Re: Sniper] #2699908
09/22/19 05:30 PM
09/22/19 05:30 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Pipe thread? Always a teflon pipe tape or paste.
Re: New Petcock [Re: CMcAllister] #2699918
09/22/19 06:28 PM
09/22/19 06:28 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
Re: New Petcock [Re: TJP] #2699996
09/22/19 10:48 PM
09/22/19 10:48 PM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
If it doesn't have to be restoration-accurate, I like the ones with a little hose bib extension.
If you add a short length of hose to the bib, the coolant drains past the lower radiator support.
Re: New Petcock [Re: topside] #2700081
09/23/19 10:43 AM
09/23/19 10:43 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I recently had 3 of those from different sources in which the 'wing" used for tightening and loosening just spun. the last one was front NAPA at $12.00, more than twice the price of the other 2. BTW, They appeared identical, mad
Re: New Petcock [Re: TJP] #2700096
09/23/19 11:14 AM
09/23/19 11:14 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Ran into the same thing from my NAPA part as well, had to use a punch in the hole to peen the crimp down tighter.
Re: New Petcock [Re: topside] #2700108
09/23/19 11:47 AM
09/23/19 11:47 AM
Hello again. Okay, I've have 1 member who said no sealant needed and 2 members who say use some sort of a sealant. Anyone else care to comment? Thanks..
Re: New Petcock [Re: BlueRacer69] #2700115
09/23/19 12:11 PM
09/23/19 12:11 PM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
Yes on sealant for pip threads, I prefer the paste.
As for the faulty petcocks, I haven't had that problem, but they're a lot cheaper than $12 at my local hardware store.
Re: New Petcock [Re: topside] #2700313
09/24/19 12:53 AM
09/24/19 12:53 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Brass on brass pipe thread low pressure; threads would distort enough to seal a low pressure system. Put any type sealant on it & you won't have to tighten that much to prevent even seepage.
Re: New Petcock [Re: PhillyRag] #2700552
09/24/19 06:52 PM
09/24/19 06:52 PM
5thAve Offline
5thAve  Offline
The ones I've bought usually already had some sort of sealant on it.
The last time I needed one was a few years ago and every one I tried had the problem with the wing that spun before it was tight. I ended up buying a compressor drain valve that looked the same but made better for about the same price. No problems since.
Re: New Petcock [Re: BlueRacer69] #2700777
09/25/19 01:13 PM
09/25/19 01:13 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I'm going to s*it on both sides of the fence; I've done it both ways in many situations. Brass on brass and about any other type including a steel motorcycle tank, the brass (or, in the case of aluminum, the Al threads) will deform just enough to seal if I was too cheap to buy tape or dope. With the addition of sealant, its like very inexpensive assurance.
Re: New Petcock [Re: Scott Carl] #2700794
09/25/19 02:38 PM
09/25/19 02:38 PM
This is a NOS petcock going into a original factory 69 radiator. Maybe I should ask how did the factory do it back then. I do have both pipe dope and teflon tape in my toolbox, so no big deal. I just like keeping things as original as possible. Many thanks.
Re: New Petcock [Re: BlueRacer69] #2700797
09/25/19 02:42 PM
09/25/19 02:42 PM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
Only if you anticipate having to remove it in the future. In that case pipe dope or teflon would be cheap/easy insurance IMO.
Re: New Petcock [Re: 5thAve] #2700908
09/25/19 07:24 PM
09/25/19 07:24 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree on both
Yes sealant. Loctite blue works excellent and you can wipe off the excess.
On the drains, Exactly what I did, bought 10 or them, made by Milton in this country smile But they don't have the little extension om the end for a hose, BUMMER! frown
The parts store ones cost me about 3 hours or more of utter frustration flame ozbbq
Re: New Petcock [Re: BlueRacer69] #2700990
09/26/19 12:07 AM
09/26/19 12:07 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Quote
Doubt the factory had the worker applying tape or sealant on every valve they installed. Factory would have ordered valves with a sealant already applied to threads, if they used any at all. Typical of any production/assembly factory workings.
