B motor 512 cam advice
#2699866
09/22/19 01:51 PM
09/22/19 01:51 PM
Posts: 114 Oklahoma City, Oklahoma
MrMayhem
https://www.compcams.com/magnum-250-250-solid-flat-cam-for-chrysler-383-440.htmlHey all, like most of us I am on a budget and I am trying to make the most with what I have. I am building a B based 512 for 72 Duster with the goals of being somewhere in the 600-650Hp range. I am doing some parts trading to help a friend out more than myself and in the trade I an going to end up with a Comp cams Magnum 250/ solid cam and lifters. Is there any opinion on this cam that could be shared and how it might perform in the theoretic 512 B based combo with a heads the flow 300 cfm. How well would this cam perform in the 512 packed noted below? Currently I have a set of fully ported Bruce Toth heads (same casting as the Marsh performance heads), Set of Crane Gold 1.6 rockers I bought new many years ago, 2 intakes to choose from Eddy RPM and a M1 single plane, both intakes being fully ported and gasket matched. With a Quick Fuel 850 dp to top it off until I go EFI. As per a previous post I am still waiting to purchase my bottom end but I except to do so in the next 2 months. Also on the shelf is a Comp Cams XE284 that I feel is a bit small for the goal I trying to reach. Thanks
Re: B motor 512 cam advice
[Re: MrMayhem]
#2699880
09/22/19 02:45 PM
09/22/19 02:45 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
cam is to small in my opinion. add some lift & about 10 to 15 deg of duration , that 250 cam will be in the 550 hp range at best with 300 cfm in my opinion, call & talk to Dwayne Porter, Porter Racing Heads
[Re: AndyF]
#2700106
09/23/19 11:44 AM
09/23/19 11:44 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
No specific cam recomendation hear, just an opinion on cam choice. Write down the charactotistics you want in a cam. Things like maintenance intervals, where you want it to smooth out so it can work well with your trans, quality of parts you are willing to buy. Add anything else you think is important. The LAST thing you want on your list is a horsepower goal. That often forces the builder into a compromise they may not like for a mostly street car.
[Re: gregsdart]
#2700356
09/24/19 08:18 AM
09/24/19 08:18 AM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
No specific cam recomendation hear, just an opinion on cam choice. Write down the charactotistics you want in a cam. Things like maintenance intervals, where you want it to smooth out so it can work well with your trans, quality of parts you are willing to buy. Add anything else you think is important. The LAST thing you want on your list is a horsepower goal. That often forces the builder into a compromise they may not like for a mostly street car. LOL, that's the opposite of how I do it. I start w/ the power I want, then compromise everywhere else! In all seriousness, Greg gives good advice here. I'm just willing to deal w/ more than most on the street to get the performance I'm after.
[Re: AndyF]
#2700528
09/24/19 05:11 PM
09/24/19 05:11 PM
MrMayhem
If you are mostly driving on the street then that 294S with the 1.60 rockers and the Performer RPM should be a good combo. Especially if you want to cruise down the freeway to a car show. I'd put it together with that combo and drive it for a year and see how it works for you. Once you get some miles on it you can change your mind. The more I think about it, the more I agree with you Andy. The 16 year old racer in me wants a 700 hp monster but in reality, I don't think I would enjoy driving a race car as much as I want to drive this. I have been following your Duster build very closely and love the work you do and your articles. I am at the point where I have everything I need to build this engine minus the rotating assembly. I hope to have that purchased in the next 2-3 weeks or I'll blow the cash on something else I dont need lol. I just want to make sure it's done right the first time so it only needs done once. Thanks for the input
[Re: MrMayhem]
#2700596
09/24/19 08:53 PM
09/24/19 08:53 PM
Posts: 150 It's Complicated
HDNMOPERS
It's Complicated
This is what I'm running in my low deck 512. With 1.6 RAS rockers B3 Geometry set up 10.3 comp Trick Flow 240s M1 single plane both ported by Larry Smith with a 850 Thumper carb. Been to busy with work to dyno. But will be on the pump in about a week or so. I will post results. Hoping for any where between 590-610 hp. Will see though. Not chasing a number. It will make what it makes. But should be a real nice pump gas street engine.
[Re: HDNMOPERS]
#2700829
09/25/19 03:30 PM
09/25/19 03:30 PM
MrMayhem
This engine will certainly hit the dyno. I am not opposed to going larger with the cam, I can afford to spend an extra $300-500 to make it perform more to it's potential. Though I still need some sensibility as it will be driven on the street on the weekends going to and from various events. That being said... it was your money what cam would you install?
[Re: MrMayhem]
#2700835
09/25/19 03:50 PM
09/25/19 03:50 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
We started here because the car will be driven to shows 5-6 hrs away. I seem to recall talk of an overdrive trans, conservative gearing, and a fairly heavy vehicle being part of the mix as well. One size def doesn’t fit all.
[Re: MrMayhem]
#2700838
09/25/19 03:58 PM
09/25/19 03:58 PM
HDNMOPERS
It's Complicated
What I installed or what you already have. This car will be used with the same intended use as yours. Im thinking the next cam. If I even do another cam it will still be conservative also. But more like 560-570 lift with 1.6 rockers and roughly 250-260 range @50. But thats just me. I like my pure street stuff more conservative than others.
[Re: fast68plymouth]
#2700842
09/25/19 04:00 PM
09/25/19 04:00 PM
HDNMOPERS
It's Complicated
Thats exactly right Mr Porter. And I think you nailed it with the cam for this build and it's intended use. Matt Hensley thought it was a very good cam for this engines application. During the build.
[Re: CSK]
#2703294
10/03/19 12:46 AM
10/03/19 12:46 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
cam is to small in my opinion. add some lift & about 10 to 15 deg of duration , that 250 cam will be in the 550 hp range at best with 300 cfm in my opinion, call & talk to Dwayne Porter, Porter Racing Heads I agree as I run a Dwayne Porter solid flat tappet cam in my pump gas 493 street car and I love it. He knows his stuff so I would give him a call. Good luck , Ron
