Roller cam and rocker manufacturer reccomendation? #2699862
09/22/19 01:27 PM
09/22/19 01:27 PM
God's Country - Etowah, TN.
A34 Offline OP
A34  Offline OP
Hey Guys,
Who do you recommend for a roller cam, lifters and rocker arm assembly? Also, who do you NOT recommend. This is for a mild 440.
Thanks in advance!
God Bless America, Our Troops and Their Families !
DEO VINDICE
Re: Roller cam and rocker manufacturer reccomendation? [Re: A34] #2699883
09/22/19 03:03 PM
09/22/19 03:03 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
I asume you are talking about hydrolic so i would recomend morel lifters and talk to Duane Porter about your cam choise would be my best bet for a great result.
Re: Roller cam and rocker manufacturer reccomendation? [Re: A34] #2699887
09/22/19 03:40 PM
09/22/19 03:40 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Don't skimp.
Junk is cheaper for a reason.
Re: Roller cam and rocker manufacturer reccomendation? [Re: A34] #2699893
09/22/19 04:11 PM
09/22/19 04:11 PM
AndyF Offline
AndyF  Offline
For a mild 440 I'd go with parts from Comp Cams. Cam, lifters and rockers.
Re: Roller cam and rocker manufacturer reccomendation? [Re: Mopar Guy] #2699900
09/22/19 04:45 PM
09/22/19 04:45 PM
A34 Offline OP
A34  Offline OP
Thanks! Yes, Hydraulic roller.
Would you have contact info by chance?
DEO VINDICE
Re: Roller cam and rocker manufacturer reccomendation? [Re: A34] #2699939
09/22/19 08:11 PM
09/22/19 08:11 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Eight zero two - nine five one- one nine five five he’s usually in from about 9am-6pm
My opinion, and Dwayne may disagree, is my first choice wouldn’t be Comp hyd. roller lifters, and even wouldn’t suggest Morels at this point, based on some current trends. Dwayne knows how to catch me if need be. Dwayne will get you a good cam, stick with his advice.
RIP Monte Smith
Re: Roller cam and rocker manufacturer reccomendation? [Re: CompWedgeEngines] #2700022
09/23/19 05:00 AM
09/23/19 05:00 AM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
What kind of some current trends regarding morels lifters ? I never heard of any going bad ! I have seen comp cams roller lifter that pin for roller came out !
Re: Roller cam and rocker manufacturer reccomendation? [Re: Mopar Guy] #2700095
09/23/19 11:13 AM
09/23/19 11:13 AM
Any company that makes a bunch of products for racing will have some failures, Morel has some also shruggy
Some people, car guys, can screw up a wrecking ball in a sand box with a feather shruggy work
Re: Roller cam and rocker manufacturer reccomendation? [Re: A34] #2700099
09/23/19 11:16 AM
09/23/19 11:16 AM
Call Comp Cams 800-365-9145, Bullet 662-893-8022 and Ultra Dyne 662-893-8022 and compared there recommendations for you and go from there.
As far as hydraulic roller lifters I don't use them due to not being able to get good trouble free lifters from any company out there so far whiney
Adjustable rocker arms are a different deal all together, don't buy cheap import aluminum roller tips, NO GOOD down
As already mentioned Comp Cams stainless steel, Crane aluminum and ductile iron rockers, Isky ductile iron and maybe RAS 530242-1316 if they have any in stock and maybe Hughes aluminum for street use shruggy
ROOMS @ CARLISLE
by Magnumguy. 06/06/20 12:29 PM
Fully informed rental vehicle buying?
by 360view. 06/06/20 10:37 AM
70 Bee Fender Emblem Placement
by HILOGTX. 06/06/20 10:29 AM
Moparts Recent Posts
Picked up my new toy
by larrymopar360. 06/06/20 12:38 PM
Best wax for daily drivers that live outside?
by larrymopar360. 06/06/20 12:35 PM
