AR Engineering 36-1 trigger on a small block #2348634
08/04/17 07:21 PM
08/04/17 07:21 PM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
Do any of you guys have this trigger setup on a small block? I'd like to see where you have the sensor mounted in order to make it all work.
Thanks guys.
Re: AR Engineering 36-1 trigger on a small block [Re: rgreule] #2348887
08/05/17 11:05 AM
08/05/17 11:05 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
the SDC 36-1 trigger wheel kit. mounts the sensor on the passenger side. if needed I can post some pics later today
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: AR Engineering 36-1 trigger on a small block [Re: Jerry] #2348923
08/05/17 11:55 AM
08/05/17 11:55 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Jerry, just a heads up, your website has been down for the last couple of days- that I know of.
"Talking tough is easy when it's other people's evil and you're judging what they do or don't believe" Mike Cooley / Drive-By Truckers Razor and Tie Music (BMI)
Re: AR Engineering 36-1 trigger on a small block [Re: rgreule] #2349129
08/05/17 06:27 PM
08/05/17 06:27 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I used a MSD crank trigger mount on the passenger side for my sensor. I was running a 36-1 wheel a friend cut out for me and I switched to Andy's wheel when he released it, nice piece!
Edit, top pic is before Andy's wheel. I need to snap a new pic because it looks all fancy down there now with the Doty pulley and billet 36-1 wheel haha.
68 Barracuda Formula S 340
Re: AR Engineering 36-1 trigger on a small block [Re: rgreule] #2349687
08/06/17 07:13 PM
08/06/17 07:13 PM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
I like that.. I can't decide to try to setup a 36-1 or a msd 4x with a hall sensor on it.
Re: AR Engineering 36-1 trigger on a small block [Re: Bad340fish] #2698852
09/19/19 02:19 AM
09/19/19 02:19 AM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
Do you have any updated pics of this?
Also is that the ZF/cherry sensor?
Re: AR Engineering 36-1 trigger on a small block [Re: rgreule] #2699253
09/20/19 01:25 PM
09/20/19 01:25 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I can take one when I get home with it on the car. Yes that is a cherry sensor.
Re: AR Engineering 36-1 trigger on a small block [Re: Bad340fish] #2699423
09/21/19 12:19 AM
09/21/19 12:19 AM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
I used SD concepts mounted on the driver side. Had to get a bit milled off the sensor mounting surface to get the airgap correct for microsquirt.
Re: AR Engineering 36-1 trigger on a small block [Re: j.mcconnell] #2699440
09/21/19 07:36 AM
09/21/19 07:36 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
This is the best picture I could get installed. It took some doing with MSD to buy the parts for the mount. They sell the crank trigger pieces individually but the people on the phone aren't real good at knowing what is what. The blank aluminum tab came from a universal kit they used to offer and the mount is just a regular small block deal. If you go this route take a deep breath and maybe a stiff drink before you call them it was interesting. Maybe its better now that Holley owns them?
The SD concepts piece wasn't around when I did this project but it looks very nice. I have his adapter to use a Jeep Cam sensor in place of a distributor and it is very nice.
I need to remove the wheel and clean it up and paint it or have it anodized. It looked so pretty in its bare billet form but it is starting to rust a little. I think he sells them coated, this was an early one.
Re: AR Engineering 36-1 trigger on a small block [Re: j.mcconnell] #2699441
09/21/19 07:40 AM
09/21/19 07:40 AM
MR_P_BODY Online content
MR_P_BODY  Online Content
I have mine mounted on the drivers side also.. works great
wave
Re: AR Engineering 36-1 trigger on a small block [Re: MR_P_BODY] #2700656
09/25/19 02:25 AM
09/25/19 02:25 AM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
Thanks for the replys guys. I'm gonna check out the ad mount and the mad and see what I can find. I've never set one up before or done the research but I assume since there are people putting the sensor on either passenger or driver side that it works both ways. Where is the sensors supposed to go in relation to tdc?
Re: AR Engineering 36-1 trigger on a small block [Re: rgreule] #2700667
09/25/19 05:24 AM
09/25/19 05:24 AM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
Innovators west makes a nice bracket that places the sensor on the driver's side
Re: AR Engineering 36-1 trigger on a small block [Re: rgreule] #2700671
09/25/19 06:17 AM
09/25/19 06:17 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
With my setup(Megasquirt MS3X) it doesn't matter, there is an adjustment for the sensors position in relation to TDC and the missing tooth. I am sure other systems have something similar.
Re: AR Engineering 36-1 trigger on a small block [Re: Bad340fish] #2700710
09/25/19 08:52 AM
09/25/19 08:52 AM
Post falls, Idaho
rgreule Offline OP
rgreule  Offline OP
Post falls, Idaho
Oh ok gotcha. I have fueltech I just haven't even opened it yet to look into it.
Thanks for the into
Re: AR Engineering 36-1 trigger on a small block [Re: rgreule] #2701884
09/29/19 12:05 AM
09/29/19 12:05 AM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
I considered the Innovators West bracket, but had plenty of adjustment or mounting options with the SDC kit and microsquirt. The SDC sensor is the same one that DIYAutotune sales and the trigger wheel is infinitely adjustable. Worked great once I got the sensor spacing set correctly.
Looks like I’m done
by -Cuda. 02/19/20 09:20 PM
leading up rockers and quarter seams??
by hulmule. 02/19/20 09:17 PM
Dana 60 rear cover ID
by SethJof. 02/19/20 09:08 PM
Big Block Turbo Kit
by 500ciDuster. 02/19/20 07:08 PM
Moparts Recent Posts
56 Olds 88 gasser - $19,800
by Jer. 02/19/20 11:27 PM
1973 Dodge Charger Rallye
by Jer. 02/19/20 11:25 PM
66 Charger - $2,500
by Jer. 02/19/20 11:23 PM
Looks like I’m done
by -Cuda. 02/19/20 11:08 PM
