Re: Baby Steps Progress Report
[Re: BradH]
#2702578
10/01/19 11:28 AM
10/01/19 11:28 AM
BradH
A couple of minor things... Decided the heads are going back up to Dwayne's after I started having cold sweats over the possibility of somebody else doing a sub-par job. Also, didn't like the raw fuel trail that was showing in the bowls behind the valve guides, so I went over the bowls & runner surfaces (but not the short turns) and put a bit o' texture on them to help w/ fuel fallout issues. Or so the theory goes... Bowl pic is "before" w/ the fuel trail highlighted; runner pic shows surface texture applied.
[Re: BradH]
#2702601
10/01/19 12:44 PM
10/01/19 12:44 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I seem to remember sending someone a set of atage 6’s where I had left the intake runners roughed up....... and they didn’t like it, so they polished them smooth. Maybe it’ll come back to me who that was.......
[Re: BradH]
#2702677
10/01/19 04:45 PM
10/01/19 04:45 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
Back when I did port work I would blast the port in the direction of flow with Black Magic abraisive , I really dont know if it helped or not, but after blasting the port flowed a little more.
[Re: BradH]
#2702684
10/01/19 04:55 PM
10/01/19 04:55 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
I seem to remember sending someone a set of atage 6’s where I had left the intake runners roughed up....... and they didn’t like it, so they polished them smooth. Maybe it’ll come back to me who that was....... Hmmm... let me know if you remember. Whomever it was, I'm sure he's an idiot. You won't be the first idiot that smooth up the intake port walls making the fuel droplets congeal and drop out and make the motor less efficient
[Re: BradH]
#2702700
10/01/19 05:33 PM
10/01/19 05:33 PM
BradH
I seem to remember sending someone a set of atage 6’s where I had left the intake runners roughed up....... and they didn’t like it, so they polished them smooth. Maybe it’ll come back to me who that was....... Hmmm... let me know if you remember. Whomever it was, I'm sure he's an idiot. Oh, I forgot to add riblets to the SSRs!
[Re: BradH]
#2702710
10/01/19 06:34 PM
10/01/19 06:34 PM
fast68plymouth
So. Burlington, Vt.
Once they leave my possession, what happens to them is beyond my control I thought riblets was something McD’s used to have....... with bbq sauce on a bun.
[Re: fast68plymouth]
#2702906
10/02/19 09:18 AM
10/02/19 09:18 AM
BradH
Once they leave my possession, what happens to them is beyond my control I feel the same way about my oldest son now that he's gone off to college. I thought riblets was something McD’s used to have....... with bbq sauce on a bun. I'll have to look and see if McDonald's is listed as one of the contributors on the research papers I've read about fluid flow over various surface textures. However, I don't recall sesame seeds being one of the surface textures tested.
[Re: lancer493]
#2707755
10/17/19 05:41 PM
10/17/19 05:41 PM
fast68plymouth
So. Burlington, Vt.
Brads motor sure didn’t seem like it was having any issues on the dyno when it was making nearly 700hp at about 7k.
Well.......nothing related to anything mechanical.
I thought the overall package worked pretty well.
Some of the carbs we tested weren’t up to snuff though.
Now........ the amount of porting required just to get the bowls sized close to anything appropriate for the 2.20/1.81 valves in the gen 2 std port version heads....... that’s another story.
#2707756
10/17/19 05:43 PM
10/17/19 05:43 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Happy to hear you are making progress hombre.
So we are going racing this spring, correct? : D
I want to see that hood scoop gulp some air!
Then you can spray it! (Kidding...okay not really)
[Re: lancer493]
#2707840
10/17/19 08:42 PM
10/17/19 08:42 PM
BradH
Yeah, the early Victor heads had a different shape to the quench area. As Dwayne mentioned, the early heads also required a lot less work to get the ports (bowls) sized within reason. Re Dwayne's other comments... NONE of my dyno carbs were close on the tune. I went through them all and sent three down to AED to be wet-flow tested. AED did some work on one, and I changed the tunes on the other two based on their test results. Other than the carb setups, the irritating oil leaks and the coolant leaks from the MLS head gaskets, the engine "could" have been run as it was dynoed. However... I got major OCD over some things about the valve train that Dwayne wasn't phased by at all. End result has been more down time, more money spent, and all for something that 20/20 hindsight says wasn't worth getting so bent outta shape over. So here I am ten years after the car last ran and two years since the engine was dynoed trying to put it all together again.
[Re: BradH]
#2707889
10/17/19 11:20 PM
10/17/19 11:20 PM
CSK
Pattison Texas
Thanks for the updates !!
[Re: CSK]
#2707891
10/17/19 11:49 PM
10/17/19 11:49 PM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
Keep at it!! missed it what type of car?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
