71 4x4 drag link
#2697436
09/14/19 12:04 PM
09/14/19 12:04 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
..Well...from one mystery to another!!!....This '71 W100 I have has power steering...the old Garrison/Eaton style with hoses everywhere! The drag link has the valve built into it with 4 pressure hoses going to and from it. This drag ling appears to have 2 ends threaded onto it with adjustable sleeves like a tie rod would have. The rear link end is quite sloppy.Problem is, nothing in the parts book, and when you do find a picture of the link, it shows a set up like and old '50's truck that had just a stud and ball with socket type. I really would like some opinions on how to source out the ends to this drag link (similar to the old Chevy 4x4 drag link ends). Of course, thread size and the taper on the stud would be critical. Any ideas??? Surely someone has come across this....
Re: 71 4x4 drag link
[Re: superwrench]
#2697904
09/15/19 10:16 PM
09/15/19 10:16 PM
Posts: 2,591 Des Moines IA
Soopernaut
Des Moines IA
There-in lies the problem....no part number in the Chrysler 70/71 truck parts catalogue or anything online....I believe that this power setup was a SERT equipment option in those years which you had to specify the SERT number off the VIN plate and contact Mopar for the numbers. Does the truck have a SERT number? I've never seen evidence that power steering was ever available on a W100/200. I have seen SERT numbers on a few W500s that had it. That system was probably retrofitted by a previous owner.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: superwrench]
#2698859
09/19/19 05:43 AM
09/19/19 05:43 AM
Posts: 4,223 ohio
ruderunner
ohio
If you're ends can be removed, pull them and check thread size and direction. Measure the stud diameter at the big and small ends and the distance between them. Also need length from center of stud to end of the threaded end.
Older Moog catalogs had dimensions listed, they might have them on their website too.
Angry white guy
[Re: ruderunner]
#2699188
09/20/19 10:55 AM
09/20/19 10:55 AM
superwrench
Basically, that's what I did today.....it appears to have the 11/16th's 18 TPI type. The Moog listings don't show anything with the proper taper on the stud,. I scoured the internet and came up with one that looks correct...actually fitting a '57-'59 truck tie rod or drag link end. We'll see I guess.....I guess I could always take the pitman arm off the box and get the tapered hole retapered if neccessary at a machine shop .
