Re: air filters
[Re: dragon]
#2699176
09/20/19 10:21 AM
09/20/19 10:21 AM
Posts: 16,517 On the run…
BloFish
On the run…
There was no significant reduction in ET for me.I’d rather run a filter.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
Re: air filters
[Re: dragon]
#2699177
09/20/19 10:22 AM
09/20/19 10:22 AM
Posts: 52,972 Romeo MI
MR_P_BODY
ALL filters have some restriction.. its a matter of how much.. if you race at a track thats dirty then you need a filter to keep the dirt out of the engine.. I dont use a filter but thats me.. K&M does have a bit more restriction than some of the other filters proven on flow bench
Re: air filters
[Re: dragon]
#2699183
09/20/19 10:35 AM
09/20/19 10:35 AM
Posts: 608 TN
1DGEMAN
TN
does any one run a air filter like a K&N drag only car did they hurt your ET K&N makes one for my hood scoop before I buy one just want some more info http://www.r2cperformance.com/clear-oval--air-cleaner-base-and-lid.aspx I know some Stock Eliminator guys that run these filters and don't remove them for heads up runs. I ran a K&N oval filter and the filter lid on my Stocker zero performance difference. If you are running a bracket car, what difference does it make if it slows the car a couple of hun. I would rather jet for it and keep trash out of my engine.
Real Men shift for themselves
Re: air filters
[Re: 1DGEMAN]
#2699196
09/20/19 11:33 AM
09/20/19 11:33 AM
Posts: 12,591 Great Neck,LI,new york
hemi-itis
I won't race without a filter. I have made test hits with the scoop and filters off and there was NO change in my AFRs.
Re: air filters
[Re: hemi-itis]
#2699251
09/20/19 02:19 PM
09/20/19 02:19 PM
Posts: 10,043 MN
JERICOGTX
MN
No way I'd run without a filter. Have seen too much junk, whether it be a rock, bolt, or rubber, fly back, and hit the car. Wouldn't want it going down the carb as well.
69 GTX
68 Road Runner
Re: air filters
[Re: dragon]
#2699298
09/20/19 05:12 PM
09/20/19 05:12 PM
Posts: 43,269 Bend,OR USA
Cab_Burge
I have use and tested K&N filters and the K&N top filters, two motors on two different dyno lost 8 HP on the dyno. My old race car went .2 ET quicker and .23 MP in the 14 mile with the top on versus with out it off with a six pack type scoop with the lid almost touching the back of the bottom edge of the scoop. I haven't race a bracket motor with out a air filer on it since 1970s
Re: air filters
[Re: Cab_Burge]
#2699385
09/20/19 09:11 PM
09/20/19 09:11 PM
Posts: 11,652 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Biggest K&N I could fit with no oil. Just trying to keep the big stuff out. I think it actually helped the car by straightening/smoothing the air in the sealed scoop. Made the cylinder walls and rest of the engine look noticeably happier
