Crankshaft pilot bearing/bushing question #2698895
09/19/19 09:13 AM
09/19/19 09:13 AM
USA
440mopar Offline OP
440mopar  Offline OP
USA
Regarding crankshafts, how do you determine whether one is drilled for a pilot bearing or bushing? I've never had the opportunity to look at the end of a crankshaft of one that has been drilled for a bushing vs. one that hasn't to see the difference. Pics would be helpful if anyone has any. Thanks.
Re: Crankshaft pilot bearing/bushing question [Re: 440mopar] #2698909
09/19/19 09:45 AM
09/19/19 09:45 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
This should help.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Crankshaft pilot bearing/bushing question [Re: Dan Brewer] #2698911
09/19/19 09:46 AM
09/19/19 09:46 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Re: Crankshaft pilot bearing/bushing question [Re: Dan Brewer] #2698922
09/19/19 10:10 AM
09/19/19 10:10 AM
USA
440mopar Offline OP
440mopar  Offline OP
USA
Thank you Dan, I appreciate it. I have one more question. If the .938 dimension is for a crank drilled for the bushing, what would the size be for one that is not?
Re: Crankshaft pilot bearing/bushing question [Re: 440mopar] #2698932
09/19/19 10:41 AM
09/19/19 10:41 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Most of the time the clearance drill is around .915". Depends on the crank. I have seen auto cranks drilled very different over the years.
Re: Crankshaft pilot bearing/bushing question [Re: Dan Brewer] #2698933
09/19/19 10:42 AM
09/19/19 10:42 AM
USA
440mopar Offline OP
440mopar  Offline OP
USA
OK, thanks again.
