Re: Valve spring pressures and testing
[Re: mopar dave]
#2698512
09/17/19 04:52 PM
09/17/19 04:52 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I would call the maker of that cam and find out what it likes. There is no such thing as a "cheap" tester!
[Re: mopar dave]
#2698598
09/17/19 10:16 PM
09/17/19 10:16 PM
Posts: 11,708 Portage,michigan
B3422W5
Portage,michigan
Dwayne specced the cam, right? Call him and ask what spring to run on it. I would assume you would have done that already back when you bought the cam?
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: mopar dave]
#2698610
09/17/19 11:11 PM
09/17/19 11:11 PM
Posts: 4,457 Washington
madscientist
Washington
Gonna pull some valve springs and test them. First, my cam is a SFT with .625/.595 actual lift after lash numbers. My current pressures are 145/410 with titanium retainers. Would this be enough? What pressures should I have up to 7000rpm? I need to get a spring tester, which one would you suggest for best accuracy under $200. This cam is in my 511 and is 270@50 on a 110. Unless the core and lifters are special, that's about all I'd go. Porter may say otherwise and I'd listen to him.
[Re: mopar dave]
#2698632
09/18/19 01:42 AM
09/18/19 01:42 AM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
We spoke about a lot of things as he gave me a bunch of his time. I can't remember if it was him or someone else saying they thought the valves pressures were on the edge of being too light. I will have to go back and reread some posts and PM's. Dwayne did say to check my pressures thou just to be sure. Anyone use the spring testers you squeeze in a vice? the one I have is junk, not even close.
[Re: CSK]
#2698642
09/18/19 06:24 AM
09/18/19 06:24 AM
BradH
We spoke about a lot of things as he gave me a bunch of his time. I can't remember if it was him or someone else saying they thought the valves pressures were on the edge of being too light. I will have to go back and reread some posts and PM's. Dwayne did say to check my pressures thou just to be sure. Anyone use the spring testers you squeeze in a vice? the one I have is junk, not even close. The first one I bought was rated to 300#. I have a calibrated checking spring and it wasn't even close. The second one I bought from a member here who was selling a "better" version of the same design rated to 600#. It checked fairly accurate the first couple of times I used it. I tried to use it again recently and it has apparently lost its mind and is reading way off. Entirely possible that I did something "wrong" with it, but I still wouldn't purchase another one if they're damaged inadvertently that easily. Don't know what I'm going to buy at this point, considering everything that has a good reputation is in a much higher price range... $400++, from what I saw looking around online last night.
[Re: BradH]
#2698653
09/18/19 07:26 AM
09/18/19 07:26 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
My Dad has one of the LSM spring testers. Like everything else they have it wasn't cheap but it seems to work very well. It is only meant to do seat pressure though as it doesn't have enough travel to test open pressures.
One interesting thing in the instructions is that you need to tap on the spring lightly with something once you get the height set to relieve any tension between the inner and outer spring, makes a noticeable difference in the reading.
68 Barracuda Formula S 340
[Re: mopar dave]
#2698654
09/18/19 07:40 AM
09/18/19 07:40 AM
Posts: 287 PA
Harry's Taxi 2
PA
We spoke about a lot of things as he gave me a bunch of his time. I can't remember if it was him or someone else saying they thought the valves pressures were on the edge of being too light. I will have to go back and reread some posts and PM's. Dwayne did say to check my pressures thou just to be sure. Anyone use the spring testers you squeeze in a vice? I have a Proform one and compared it to an LSM one and they were very close......within 5lbs if I recall correctly.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: mopar dave]
#2698657
09/18/19 08:01 AM
09/18/19 08:01 AM
Posts: 52,972 Romeo MI
MR_P_BODY
We spoke about a lot of things as he gave me a bunch of his time. I can't remember if it was him or someone else saying they thought the valves pressures were on the edge of being too light. I will have to go back and reread some posts and PM's. Dwayne did say to check my pressures thou just to be sure. Anyone use the spring testers you squeeze in a vice? I have one.. at first it was way off.. I changed the gauge 3 times to get it right.. make sure there is no air in it.. I have 1 master spring that I use to check the low and high end of the gauge.. you have get a good gauge for it
[Re: BradH]
#2698671
09/18/19 09:58 AM
09/18/19 09:58 AM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I always wondered if some of you guy shop for the he cheapest Cardiologist and Dentist too. I would rather have a good used tool than a cheap new tool. Lots of deals out there if you dont mind checking around on the Internet
[Re: mopar dave]
#2698700
09/18/19 11:22 AM
09/18/19 11:22 AM
BradH
yeah, I was looking at the 600# tester by Comp. Thought maybe it might be a good piece. Thanks for clearing this up guys. Looks like Jeg's house-brand testers are identical to what COMP sells, only Jeg's has them for about 1/2 the price. Pay your money and take your chances, I suppose. I don't know if the LSM bench testers are worth the $400+. Everything above that price level is $800 on up, unless you can find a nice used higher-end tester for a good price.
[Re: pittsburghracer]
#2698705
09/18/19 11:55 AM
09/18/19 11:55 AM
Posts: 287 PA
Harry's Taxi 2
PA
I always wondered if some of you guy shop for the he cheapest Cardiologist and Dentist too. I would rather have a good used tool than a cheap new tool. Lots of deals out there if you dont mind checking around on the Internet Maybe because now days in more cases than not the high dollar stuff is the same Chinese crap as the cheap stuff........so why piss away money to say it's a brand name. I agree with you on looking for older used stuff.....you don't realize how crappy some stuff is made today till you get your hands on some older manufactured tools.
[Re: BradH]
#2698707
09/18/19 11:58 AM
09/18/19 11:58 AM
Posts: 421 montana
BANDIT
montana
I’m with DT, very easy to check them regularly on motor with the LSM. I have an old 500# Rimac I use when they are off or to compare a used set. I’ve been offered good money for it, but it will stay bolted to my workbench. I also have the LSM on motor spring swap tools for my -1’s and 572-13’s, will even use them when heads are on bench, way more control over inadvertent stuff flying around shop. Spendier stuff, but has helped in some tight spots and good quality stuff. Jim
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
