Re: Leaf-link rear suspension.
[Re: fbs63]
#2698439
09/17/19 12:50 PM
09/17/19 12:50 PM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
My old man had tried it on his 63 Thunderbolt in the late 70s ......Yes I wish I had that car. ....I vaguely remember the car he sold it in 80 , it was always a hand full to drive....not because of power it just didn't track straight always wanted to go left, before and after the leaf link set up. here's good thread that has some useful info https://www.jalopyjournal.com/forum/threads/leaf-link-suspensions-learn-me-something.293268/
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
[Re: fbs63]
#2698440
09/17/19 12:51 PM
09/17/19 12:51 PM
Posts: 10,020 MN
JERICOGTX
MN
Just put a 4 link in the car, and start enjoying going to the track again.
69 GTX
68 Road Runner
[Re: 340Cuda]
#2698462
09/17/19 02:00 PM
09/17/19 02:00 PM
Posts: 3,069 Michigan
A727Tflite
The guys I know that have run the leaf-link have had problems bending the spring. That why the rod is on the bottom with the Caltracs setup. I know you want to be different but Caltracs is really the way to go. You have to use a thicker main leaf spring - back in the day you had to use the 002/003 spring because it’s mainleaf was thicker than the SS springs. And you had to clamp the front segment at that. There are better designs now.
[Re: 340Cuda]
#2698613
09/17/19 11:43 PM
09/17/19 11:43 PM
Posts: 874 Missouri
jwb123
Missouri
The guys I know that have run the leaf-link have had problems bending the spring. That why the rod is on the bottom with the Caltracs setup. I know you want to be different but Caltracs is really the way to go. Yep I can testify that is correct, I had a leaf link set up on a 66 cuda, and I bent the spring, when the spring bent it allowed the slick to rub the front of the fender, ruined the tire, and was lucky it did not wreck the car.
