Leaf-link rear suspension. #2698300
09/17/19 07:10 AM
09/17/19 07:10 AM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Anyone have an old Direct Connection manual they would be willing to post, pm or email me the pages and illustrations of the leaf-link rear suspension? I remember the general layout, just don't remember if there were any specific details I don't remember. I know about Caltracs and Assasin bars, just like to be different ( or difficult) as my wife says!
Re: Leaf-link rear suspension. [Re: fbs63] #2698317
09/17/19 08:52 AM
09/17/19 08:52 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Would you like to be different or consistent? work
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Leaf-link rear suspension. [Re: hemi-itis] #2698394
09/17/19 10:52 AM
09/17/19 10:52 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
The guys I know that have run the leaf-link have had problems bending the spring. That why the rod is on the bottom with the Caltracs setup. I know you want to be different but Caltracs is really the way to go.
Re: Leaf-link rear suspension. [Re: fbs63] #2698439
09/17/19 12:50 PM
09/17/19 12:50 PM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
My old man had tried it on his 63 Thunderbolt in the late 70s ......Yes I wish I had that car. ....I vaguely remember the car he sold it in 80 , it was always a hand full to drive....not because of power it just didn't track straight always wanted to go left, before and after the leaf link set up.
here's good thread that has some useful info
https://www.jalopyjournal.com/forum/threads/leaf-link-suspensions-learn-me-something.293268/
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: Leaf-link rear suspension. [Re: fbs63] #2698440
09/17/19 12:51 PM
09/17/19 12:51 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Just put a 4 link in the car, and start enjoying going to the track again.
69 GTX 68 Road Runner
Re: Leaf-link rear suspension. [Re: 340Cuda] #2698462
09/17/19 02:00 PM
09/17/19 02:00 PM
A727Tflite Offline
A727Tflite  Offline
You have to use a thicker main leaf spring - back in the day you had to use the 002/003 spring because it’s mainleaf was thicker than the SS springs. And you had to clamp the front segment at that.
There are better designs now.
Re: Leaf-link rear suspension. [Re: A727Tflite] #2698471
09/17/19 02:27 PM
09/17/19 02:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is this car for street or the track.. if street a ladder bar is far better.. fits better.. if track only then
go with a 4 link works better.. that old stuff is junk now days
wave
Re: Leaf-link rear suspension. [Re: MR_P_BODY] #2698612
09/17/19 11:39 PM
09/17/19 11:39 PM
Red Deer, Alberta
Greenwood Offline
Greenwood  Offline
Red Deer, Alberta
FWIW, my heap uses an old Morrison 4-link, with the stock leaf springs. I floated the housing via an aluminum bushing that allows the housing to rotate freely. The bushing is a two-piece that I designed and machined myself. The leafs hold the car up, and the four-link seems to work.
Re: Leaf-link rear suspension. [Re: 340Cuda] #2698613
09/17/19 11:43 PM
09/17/19 11:43 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Yep I can testify that is correct, I had a leaf link set up on a 66 cuda, and I bent the spring, when the spring bent it allowed the slick to rub the front of the fender, ruined the tire, and was lucky it did not wreck the car.
Re: Leaf-link rear suspension. [Re: jwb123] #2698650
09/18/19 07:07 AM
09/18/19 07:07 AM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Ok, thanks for the info guys!
Re: Leaf-link rear suspension. [Re: fbs63] #2699121
09/19/19 11:25 PM
09/19/19 11:25 PM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
So how come no one recommends a 3 link for street cars?
I know they are a bit more involved in set up and installation, but they are supposed to be way better than a 4 for going around corners
Re: Leaf-link rear suspension. [Re: Alchemi] #2699157
09/20/19 09:03 AM
09/20/19 09:03 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
This forum is mostly for straight line racing. In the cornering forum, the impression that I've gotten is that the cost and set up isn't a benefit until you have a dedicated race car, and then class limitations come into play. If I had unlimited (or a much higher limit) funds, I'd go IRS and get rid of the live axle. twocents
