G 60s on front of 1970 Challenger
#2697893
09/15/19 09:25 PM
09/15/19 09:25 PM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
I have a set of repro G 60/15 polyglas tires mounted on 15 x 7 390 rallye wheels that I once had on my 71 Roadrunner. Will the G 60s fit on the front of a 70 challenger without rubbing?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: G 60s on front of 1970 Challenger
[Re: TC@HP2]
#2698087
09/16/19 02:01 PM
09/16/19 02:01 PM
Posts: 18,153 Mass
DAYCLONA
Mass
Yes, but wheel backspace is important. A G60 is roughly 26.8 x 9.76 with a bit of fudge factor +/- on its actual size. I currently run a 26x10 radial (spot on in size) on a 15x8 rim with 4.5" backspace. It fits but required I roll the outter fender lip at the very top. 15x7 with 4.5" back space or a 15x8 4.75" backspace would fit a bit better. The original style 15x7 wheels with 4.25" backspace are going to create a very tight fit to the outer fender. Another consideration is that the Polyglas the OP has is more of a square tire width/edge wise than most radials, so it needs a little more turning clearance frame/fender, the largest tire I've gotten on the front of my 71 Challenger with no rubbing with rallye rims (4.250 BS) was GoodYear Eagle GT II 255/60/15 Tires vary amongst mfgs in actual size even in the same size/ratio, lots of variables like back space, ride height, etc, etc to account for... the OP is just going to have to mount them up and try them on, I've always found what fits for one guy never works out for the other, too many little variables....
[Re: DAYCLONA]
#2698145
09/16/19 05:12 PM
09/16/19 05:12 PM
RSI700VIPER
NW New Jersey
Dayclona - Isn't a G60 15 equivalent to a 255 60/15?
