Carb heat Sheild #2697965
09/16/19 08:16 AM
09/16/19 08:16 AM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Who's carb heat shields are you guys using that you like and work well.
Re: Carb heat Sheild [Re: DusterKid] #2698028
09/16/19 11:37 AM
09/16/19 11:37 AM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Carb heat Sheild [Re: BloFish] #2698052
09/16/19 12:25 PM
09/16/19 12:25 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Depends on your carb and application.
Wood or resin insulate better than metal.
For Holleys where I want to insulate the bowls from radiant intake heat, I like the GM shield (2nd-gen Z28).
It extends under the bowls & a bit at the sides too.
That and some thicker fiber gaskets each side have worked best for me in hot environments.
Re: Carb heat Sheild [Re: topside] #2698125
09/16/19 03:58 PM
09/16/19 03:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use to make my own.. I had some material from work that worked real well.. it was good
from -40F up to 2000F... wish I had more of it
wave
Re: Carb heat Sheild [Re: topside] #2698390
09/17/19 10:42 AM
09/17/19 10:42 AM
Keymar, MD
Keymar, MD
Engine is a 360 with a Victor 340 intake and Holley 750. Have issues once in a while but not all the time with the gas boiling in the carb and creates a stumble when leaving. Looking at trying to help keep the fuel cooler.
Re: Carb heat Sheild [Re: DusterKid] #2698405
09/17/19 11:21 AM
09/17/19 11:21 AM
A collage of whims
A collage of whims
Use the GM heat shield and put fire-sleeve on the fuel lines = problem solved.
Works like a charm even on an RB stuffed into an A-body in summer driving.
Re: Carb heat Sheild [Re: topside] #2699265
09/20/19 03:09 PM
09/20/19 03:09 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run this carb heat shield and a 1" phenolic spacer. Sorry I don't know what brand the heat shield is as it was laying around my garage for a long time before I used it. This setup works good for me to stop fuel boiling in hot weather. Ron
Re: Carb heat Sheild [Re: 383man] #2699289
09/20/19 04:48 PM
09/20/19 04:48 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
I run the Holley 108-51 that has extensions that go out to the ends of the bowls, in the same vein as the previously mentioned GM gasket but more expensive, I'm sure. I put it on earlier this year after I had annoying fuel boil problems on an 80* early spring day, while we were still on winter blend fuel.
We had a 10 day stretch of high 90s-low 100s days this summer. I drove my Barracuda to work most of those days, soaking up the AC. Coolant got a needle's width above 200 in city traffic, but no flooding from fuel boil after shut down and no start problems 20 minutes after shutdown. It is either a cheap heat shield or an expensive base gasket though, I'm not sure which.
