71 - 74 Cassette Player Recorder Connector CABLE #2697897
09/15/19 09:53 PM
09/15/19 09:53 PM
Detroit, Mi
michiganhotrod1 Offline OP
Detroit, Mi
Hello;
I cannot find this on the search, so here goes.
I have a Mopar Phillips Cassette Player and Recorder, and a Mopar AM/FM radio with the 7 pin plug connector. I'd like to put this in my 71 Cuda. What I need is the cable that connects these two units? From prior pages this cable is apparently 44 inches long.
My guess is this is a standard industry connector that Phillips used, Since it is hidden, a generic replacement should work.
Does anyone know the identity of these connectors, or a source to get a cable?
Thanks,
Mark
Re: 71 - 74 Cassette Player Recorder Connector CABLE [Re: michiganhotrod1] #2697942
09/16/19 02:36 AM
09/16/19 02:36 AM
None
71rm23 Offline
71rm23  Offline
None
Here ya go
https://www.ebay.com/itm/Mopar-Floor-Mount-Cassette-Cable/323001256660?hash=item4b34600ad4:g:EycAAOxyhXRTNyc-
Re: 71 - 74 Cassette Player Recorder Connector CABLE [Re: 71rm23] #2697943
09/16/19 02:57 AM
09/16/19 02:57 AM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Scott
1969 Super Bee, 383/4 speed
Re: 71 - 74 Cassette Player Recorder Connector CABLE [Re: StukaJU87] #2697945
09/16/19 05:34 AM
09/16/19 05:34 AM
None
71rm23 Offline
71rm23  Offline
None
Originally Posted by StukaJU87
Thanks Stka. Used my phone to paste but didnt know if it did it correctly
Re: 71 - 74 Cassette Player Recorder Connector CABLE [Re: 71rm23] #2697980
09/16/19 09:20 AM
09/16/19 09:20 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
If you are using a console mounted assembly the correct factory one is the short one pictured here.
Floor mount used the longer one.
The short one is hard to find.
The long ones are out there and can be found for a lot less than the advertised one.
The long one can be used even with the console mount, will work fine, just tuck it up under.
