Re: Complete axle housing choices
[Re: coro500net]
#2697576
09/14/19 07:30 PM
09/14/19 07:30 PM
RapidRobert
You might consider haveing Moser cut down some C body or truck 8&3/4 axles to A body length. they'd be BBP which I am assuming you want. then a 742 clutch sure grip pig in the ratio you want.
[Re: coro500net]
#2697806
09/15/19 04:28 PM
09/15/19 04:28 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
Been checking out the Dana S60 but once you do all your specs the price goes up quickly. I know a new complete rear is going to cost a good amount, just thought there may be a inexpensive alternative. Looking around at all the rear axle builders it looks like you have to pay to play. Shipping is a big cost also. Dr Diff sells the S60, had the best price & shipping for mine.
[Re: DoctorDiff]
#2699966
09/22/19 09:26 PM
09/22/19 09:26 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
Yep, I went with Strange S60 with a Detroit locker, 3.73 gears, 35 spline axles, and wilwood disc brakes. I bought it directly through Strange about 10 years ago, before I knew about Cass at DoctorDiff
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
