Fuel Pressure Sensor for LM2 #2697717
09/15/19 10:59 AM
09/15/19 10:59 AM
North Central, Indiana
Roughbird72 Offline OP
For those using the Innovate LM2, I'm thinking about installing a fuel pressure sensor.
What sensor have/are you guys using? shruggy
72 Plymouth Roadrunner 11.08@123.25
Re: Fuel Pressure Sensor for LM2 [Re: Roughbird72] #2697733
09/15/19 11:49 AM
09/15/19 11:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Most all use a 0-5V sensor so try to find one in that range.. also is this for a carb or injected
system.. the pressures are different
wave
Re: Fuel Pressure Sensor for LM2 [Re: MR_P_BODY] #2697767
09/15/19 01:59 PM
09/15/19 01:59 PM
wave
Carbed
Re: Fuel Pressure Sensor for LM2 [Re: Roughbird72] #2697774
09/15/19 02:23 PM
09/15/19 02:23 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Ebay search “pressure sensor 5v”
Select the range you want, be sure they include voltage scaling in the listing.
Re: Fuel Pressure Sensor for LM2 [Re: TRENDZ] #2698033
09/16/19 11:40 AM
09/16/19 11:40 AM
Thanks!
Re: Fuel Pressure Sensor for LM2 [Re: Roughbird72] #2698427
09/17/19 12:28 PM
09/17/19 12:28 PM
NY
challenger451ci Offline
NY
I believe those are powered by 5VDC. The LM-2 doesn't have a 5V supply in it. You need a sensor that can be powered on 12VDC but has an Analog output of 0-5VDC over the pressure range you're trying to read. I've used sensors from Transducers Direct with my LM-2 with good success. They're around $100. Not to say you can't find a lower cost one on eBay, just make sure they are designed to have 12V input power.
Re: Fuel Pressure Sensor for LM2 [Re: challenger451ci] #2698480
09/17/19 02:57 PM
09/17/19 02:57 PM
Sweden
Cuda_70 Offline
Cuda_70  Offline
Sweden
Here is a nice piece to get 5V for the sensor.
https://www.ebay.com/itm/Raspberry-Pi-DC-DC-Converter-Regulator-12V-Stepdown-to-5V-3A-15W-Module-Power/142752974294?hash=item213cbd85d6:g:JXQAAOSw5cNYcSC7
Re: Fuel Pressure Sensor for LM2 [Re: Cuda_70] #2698529
09/17/19 06:20 PM
09/17/19 06:20 PM
NY
NY
Hey now! That's pretty alright. I've looked around for something since most sensors are 5VDC supply. Very cool.
