Cooling issue (revisited)
#2697769
09/15/19 02:04 PM
09/15/19 02:04 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
So I had a post a while back about a cooling issue on my 74 Challenger, 318/904 car mild cam, cast iron 4bbl manifold, Carter AVS, Magnum exhaust. With 2 core aluminum aftermarket radiator, I couldn't keep it under 220 - 230*. Switched to a 3 core and I can run 200 and under even with a 180* thermostat. However, after about a half hour run, (Good and warmed up), it starts crapping out at WOT, stalling at stops and hard to re-start. I believe its fuel starved. It starts long enough for the started to quit turning then dies. After several attempts it will start but run but erratically. Misses and runs rough at anything over an idle until its cool again.
Question: Will a weak fuel pump act this way when it gets hot? Carb too hot and boiling fuel in bowl? Timing issue; Weak advance springs? Runs great at first but tends to feel starved at WOT
Thanks Scott
Re: Cooling issue (revisited)
[Re: TJP]
#2697871
09/15/19 08:52 PM
09/15/19 08:52 PM
Scott Carl
Omaha, Nebraska
Sounds a bit like vapor locking but could be a heat sensitive ignition component as well. You're not running ethanol based fuel are you ?? Yes, actually I do tend use ethanol
[Re: Scott Carl]
#2697885
09/15/19 09:14 PM
09/15/19 09:14 PM
RapidRobert
Scott what ign do you have? Robert, its just a stock ignition That's good news. Was it acting up when you had the cooling issue?
[Re: RapidRobert]
#2697896
09/15/19 09:30 PM
09/15/19 09:30 PM
Scott Carl
Omaha, Nebraska
Scott what ign do you have? Robert, its just a stock ignition That's good news. Was it acting up when you had the cooling issue? Yes. I assumed at that time, it was a heat related issue. In fact, with the 2 core radiator, on a couple occasions, it seemed to get so hot, it shut down and wouldn't restart for a couple hours. BTW, I have a new temp gauge, finally. The old one was sticky and never did go all the way to 0*
[Re: Scott Carl]
#2698780
09/18/19 07:44 PM
09/18/19 07:44 PM
Posts: 15,304 Omaha Ne
TJP
Omaha Ne
Sounds a bit like vapor locking but could be a heat sensitive ignition component as well. You're not running ethanol based fuel are you ?? Yes, actually I do tend use ethanol Ethanol based fuels have a lower boiling point than non ethanol fuels and can wreak havoc in older carbureted vehicles with the temperatures we've been experiencing. \ I would start by getting it out of the system ASAP. Other changes may also be required if it is vapor lock and changing fuel does not resolve the issue.
