Tremec TR6060 Six speed Hemi Swap #2677345
07/14/19 03:47 PM
07/14/19 03:47 PM
Right Coast
Fabman Offline OP
Fabman  Offline OP
Right Coast
Im installing a 6.4 with the TR6060 into a 70 B body. Ok....nothing new here....but like all other transplants of this type I have to install the mid sump oil pan, Nothing new there either.....BUT....what have other people done about the dust cover needed in front of the Trans (TR6060) that is missing when you take the factory oil pan off the engine. AND ….has anyone considered the structural support needed to be installed between the TR6060 and the block...…...That was removed when the factory oil pan was removed?
Re: Tremec TR6060 Six speed Hemi Swap [Re: Fabman] #2697432
09/14/19 12:00 PM
09/14/19 12:00 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I know what you mean , i have a 6.2 with a truck oil pan and 6 speed and its holding up fine but more support would be better.
Re: Tremec TR6060 Six speed Hemi Swap [Re: 70blackfish] #2699049
09/19/19 06:23 PM
09/19/19 06:23 PM
ghinmi Offline
ghinmi  Offline
I too ran one with a truck oil pan and no support. Originally with the factory bellhousing and now with a quicktime. No issues. Lots of miles and passes.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street.
9.97 @ 140 slicks, 10.74 in autox trim
Re: Tremec TR6060 Six speed Hemi Swap [Re: Fabman] #2699800
09/22/19 11:25 AM
09/22/19 11:25 AM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
the 408 (G3) that's in 2010 Challenger has had 15k put on it with out the "stock pan support" mid 10sec street car since I bought it 2 years ago now, before that it had 55k put on the old 383 5.7 stroker since 2011 run mid to low 12s all that time.
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
