1965 Dodge Coronet 500 #2492781
05/06/18 01:37 PM
05/06/18 01:37 PM
AndyF Offline OP
AndyF  Offline OP
I've had this car for a long time. It was a street racer back in the 70's and then a daily driver during the 80's. It sat in my shop for most of the past 20 years. I'm now starting to work on it a bit and hope to have it back on the streets this summer.
Re: 1965 Dodge Coronet 500 [Re: AndyF] #2492782
05/06/18 01:40 PM
05/06/18 01:40 PM
AndyF Offline OP
AndyF  Offline OP
I'm spending a little bit of time in the interior cleaning things up. One mistake I made over the past 20 years was ignoring the chrome. I should have polished the chrome once every few years but I didn't and now most of it has small rust pits. So I think I'll need to pull the chrome and have it redone.
Re: 1965 Dodge Coronet 500 [Re: AndyF] #2492808
05/06/18 02:43 PM
05/06/18 02:43 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
nice! the '65s have great lines.
1981 Dodge D150 360 auto
Re: 1965 Dodge Coronet 500 [Re: basketcase] #2492836
05/06/18 04:40 PM
05/06/18 04:40 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
One of my favorite cars on Moparts!
'63 Dodge 330
11.19 @ 121 mph
Re: 1965 Dodge Coronet 500 [Re: AndyF] #2493654
05/08/18 02:57 PM
05/08/18 02:57 PM
AndyF Offline OP
AndyF  Offline OP
I weighed the car today and found out that it is heavier than I thought. Good news is the weight distribution is pretty good. 51% up front and 49% in the rear. The gas tank is almost empty so if I filled up the tank the car would have a 50/50 weight distribution front to rear. The bad news is that the car is almost 3800 lbs with nobody in it. If I filled up the gas tank the car would weigh over 3800 lbs.
Re: 1965 Dodge Coronet 500 [Re: AndyF] #2494003
05/09/18 04:03 PM
05/09/18 04:03 PM
KY
65pacecar Offline
65pacecar  Offline
KY
Great build. One of my all time favorite body styles. I love 65 Coronets. Looking forward to following this one.
Re: 1965 Dodge Coronet 500 [Re: AndyF] #2494111
05/09/18 09:12 PM
05/09/18 09:12 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Isn't gasoline about 6 lbs/gallon? I'd imagine with an extra 12 gallons, it would weigh almost 75 lbs more.
Still cool you'd be able to achieve almost 50/50. How did you do it? Fiberglass body panels?
Re: 1965 Dodge Coronet 500 [Re: AndyF] #2494130
05/09/18 10:08 PM
05/09/18 10:08 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Curb weight...
Thirty-four hunert OEM...
Re: 1965 Dodge Coronet 500 [Re: MuuMuu101] #2495358
05/13/18 12:58 AM
05/13/18 12:58 AM
AndyF Offline OP
AndyF  Offline OP
No fiberglass, the body is all steel. The 50/50 weight is due to having the battery in the trunk as well as having a fairly lightweight engine. Aluminum heads, aluminum intake, aluminum carb, mini starter, aluminum water pump housing, aluminum radiator, etc.
Re: 1965 Dodge Coronet 500 [Re: AndyF] #2496011
05/14/18 03:16 PM
05/14/18 03:16 PM
AndyF Offline OP
AndyF  Offline OP
I've driven it a few times and worked on a few bugs. I think I made a mistake by putting an aluminum flywheel in it. The car works great once it is over 2000 rpm but it really doesn't like driving slow. Even with the steep first gear ratio it will start lugging at low speeds. Some of that could be the carb since I have a 1050 on there at the moment. I'll see how much of that lugging problem is solved with the EFI. If that doesn't solve it then I'll have to pull the engine and swap flywheels.
Re: 1965 Dodge Coronet 500 [Re: AndyF] #2548358
09/10/18 01:22 PM
09/10/18 01:22 PM
AndyF Offline OP
AndyF  Offline OP
Pulled out the original '69 Dana 60 and now I'm working on installing the new S60. The new rear end has 3.23 gears, helical diff, 35 spline axles, billet pinion yoke and a Doctor Diff rear disc setup.
Re: 1965 Dodge Coronet 500 [Re: AndyF] #2548362
09/10/18 01:24 PM
09/10/18 01:24 PM
AndyF Offline OP
AndyF  Offline OP
Also got the Coronet over to the chassis dyno recently. Ran great with the new Holley Sniper setup and it made 485 rwhp. Sounded good and pulled hard.
https://youtu.be/xG3-_YJGdZ8
Re: 1965 Dodge Coronet 500 [Re: AndyF] #2548653
09/11/18 04:11 AM
09/11/18 04:11 AM
Medford OR
FrankenScamp Offline
Medford OR
Cool video, and even cooler car.
Cheers! thumbs
Re: 1965 Dodge Coronet 500 [Re: AndyF] #2556624
09/30/18 01:45 PM
09/30/18 01:45 PM
AndyF Offline OP
AndyF  Offline OP
The old Coronet got a little ink in Hot Rod recently: https://www.hotrod.com/articles/holley-hyperspark-install-tune/
Re: 1965 Dodge Coronet 500 [Re: AndyF] #2561761
10/10/18 02:43 AM
10/10/18 02:43 AM
AndyF Offline OP
AndyF  Offline OP
Picked up a steel hood scoop for the car so this will be one of the winter time projects. I'm still thinking about how to go about mounting it.
Re: 1965 Dodge Coronet 500 [Re: AndyF] #2567613
10/22/18 12:58 AM
10/22/18 12:58 AM
Mt.Gilead, Ohio
OhioMopar Offline
Happy Birthday OhioMopar  Offline
Mt.Gilead, Ohio
Cool project, Andy. I love the '65's. I thought they were a little lighter, as well.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 1965 Dodge Coronet 500 [Re: AndyF] #2609426
01/20/19 06:09 PM
01/20/19 06:09 PM
AndyF Offline OP
AndyF  Offline OP
I pulled the 512 inch low deck out and am in the process of building a 426W for the car. I have an original 426W block but I'll use Trick Flow heads and a 4.250 stroke crank to pump it up a bit. Should make 550+ hp.
Re: 1965 Dodge Coronet 500 [Re: AndyF] #2609429
01/20/19 06:12 PM
01/20/19 06:12 PM
AndyF Offline OP
AndyF  Offline OP
I've had factory HP manifolds on the car for the past 20 years but I've decided to use headers with the new 426W engine. I bought a set of Schumacher try-y headers but of course they don't fit with the Lakewood bellhousing.
Re: 1965 Dodge Coronet 500 [Re: AndyF] #2688587
08/16/19 10:31 PM
08/16/19 10:31 PM
Virginia's Eastern Shore
dmoore Offline
dmoore  Offline
Where is this project currently?
Re: 1965 Dodge Coronet 500 [Re: dmoore] #2697012
09/12/19 09:09 PM
09/12/19 09:09 PM
Atco NJ
Mr Bojangles Offline
Atco NJ
I was thinking the same thing !
1965 Belvedere II 440 4psd 4.10 Driver 1966 Belvedere II Race Car Project 1970 Duster Street Car Project 2003 Hemi Ram Quad Cab 4x4
