Re: thread chaser taps, which ones to get
[Re: RapidRobert]
#2696766
09/11/19 11:39 PM
09/11/19 11:39 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I have the craftsman set, it does NF, NC and Metric...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#2696788
09/12/19 01:00 AM
09/12/19 01:00 AM
Posts: 7,471 Minnesota
Hemi_Joel
Minnesota
I have the craftsman set, it does NF, NC and Metric... Same here, very happy with them. Made in the USA. They don't really cut, they clean and re-shape. So you don't lose metal. I wouldn't trust HF for these. If the sizes are off, or if they shatter in the hole, like most HF stuff is garbage, you just messed up your block.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: RapidRobert]
#2696810
09/12/19 08:43 AM
09/12/19 08:43 AM
Posts: 11,894 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have a couple sets of HF tap and die sets. They work fine. I don't use them real often but they are real handy when I need them. If you were going to make your living with them or want to hand them down to your grandchildren, then it would be best to spend the coin and get some more expensive ones. But for the occasional job, they have been well worth it for me.
Master, again and still
[Re: DaveRS23]
#2696821
09/12/19 09:26 AM
09/12/19 09:26 AM
Posts: 1,098 Massillon, Ohio
cudatom
Massillon, Ohio
I have a couple sets of HF tap and die sets. They work fine. I don't use them real often but they are real handy when I need them. If you were going to make your living with them or want to hand them down to your grandchildren, then it would be best to spend the coin and get some more expensive ones. But for the occasional job, they have been well worth it for me. Agreed. I have used my HF ones often and never a problem.
Ok
[Re: cudatom]
#2696866
09/12/19 11:55 AM
09/12/19 11:55 AM
Posts: 19,239 north of coder
moparx
roll/form taps work well for chasing threads as well, because they "form" or "roll" the threads instead of removing material as regular taps. something to consider if you only want to buy a couple. they also come in coarse, fine, and metric.
[Re: RapidRobert]
#2696884
09/12/19 01:03 PM
09/12/19 01:03 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
"Whenever you’re faced with dirty or slightly burred female threads (cylinder head threaded holes in a block, spark plug holes in a head, etc.), you may be tempted to grab an appropriate size cutting tap to clean up the threads. The correct choice is to use a “chaser” tap. A cutting tap is designed to create new threads, whereas a chaser tap is designed to clean, re-form and restore existing threads." https://www.summitracing.com/parts/...Q7eHL5AIVuSCtBh28YwNjEAQYASABEgKgTPD_BwE
[Re: John_Kunkel]
#2696885
09/12/19 01:15 PM
09/12/19 01:15 PM
Posts: 2,603 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
"Whenever you’re faced with dirty or slightly burred female threads (cylinder head threaded holes in a block, spark plug holes in a head, etc.), you may be tempted to grab an appropriate size cutting tap to clean up the threads. The correct choice is to use a “chaser” tap. A cutting tap is designed to create new threads, whereas a chaser tap is designed to clean, re-form and restore existing threads." https://www.summitracing.com/parts/...Q7eHL5AIVuSCtBh28YwNjEAQYASABEgKgTPD_BwE Exactly. That is what you want to use to clean every thread before assembly. And to find out if there is a problem. Taps are to cut threads and I don't want to remove material unless the thread needs repair. But you still will want a complete tap and die set and bottoming taps for other thread repairs. Even a HF set will work and last the rest of your life. (OK, I'll admit I have a tool fetish. But when I need something, I have it.)
2011 Drag Pak Challenger
[Re: 451Mopar]
#2697000
09/12/19 08:20 PM
09/12/19 08:20 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Of course, using the right style of tap for the particular job is the best thing to do........technically.
In reality, for most of us that will use the tap one time on a set of threads to clean them up or to make a set of threads, any tap will be better than nothing.
[Re: Gavin]
#2697145
09/13/19 11:11 AM
09/13/19 11:11 AM
Posts: 350 Mequon, WI
gzig5
Mequon, WI
I have a set of the cheap Summit ones and have used them effectively. If you are really cheap or just in a fix then just cut a vertical slot or two in the threads of a bolt and use that, you'll get the same result. For the price of the Summit ones, it's probably cheaper just to buy them than make your own.... This^^^. For $10 the summit ones are nice to have. But if you are missing a size, a grade 8 (preferably) bolt and dremel cutoff wheel will create the exact same thing it about one minute.
