GEN III Hemi Accessory Drive
#2694755
09/05/19 06:23 PM
09/05/19 06:23 PM
Posts: 114 Katy, TX
Bakaruda
Katy, TX
Does anyone know of one other than March Performance?
1969 Barracuda GENIII Hemi 2019 Ram 1500 Laramie
Re: GEN III Hemi Accessory Drive
[Re: Bakaruda]
#2695121
09/07/19 07:27 AM
09/07/19 07:27 AM
Posts: 1,111 Usa
A39Coronet
Usa
Since noone answered, just curious, why not run with the stock timing cover and the oe setup?
[Re: Jerry]
#2695798
09/09/19 01:53 PM
09/09/19 01:53 PM
Posts: 2,254 IL
furious70
IL
Hey Jerry - did you look at just an alternator and water pump option more geared to racing? Another piggy back application I could see is 'correcting' the car setup that puts the alt into the a arms on the old cars. Relo the alt somewhere with some brackets and a new belt. I'd be in the market for both of those
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Jerry]
#2695990
09/09/19 11:16 PM
09/09/19 11:16 PM
Posts: 124 Southern Missouri
Wailin D
Southern Missouri
Try Jones Racing Products at http://www.jonesracingproducts.com/. They have serpentine belt systems for the Gen3 Hemi. One system they have has just the alt and power steering and one has the alt, power steering and AC compressor. One major benefit of their system is that they can customize the pressure of the power steering pump so it can be used with the newer rack and pinion or set to a lower pressure for the older steering boxes. I will try to attach some pictures they sent me.
[Re: Wailin D]
#2696115
09/10/19 12:08 PM
09/10/19 12:08 PM
Jamey
Did they give you any prices? Try Jones Racing Products at http://www.jonesracingproducts.com/. They have serpentine belt systems for the Gen3 Hemi. One system they have has just the alt and power steering and one has the alt, power steering and AC compressor. One major benefit of their system is that they can customize the pressure of the power steering pump so it can be used with the newer rack and pinion or set to a lower pressure for the older steering boxes. I will try to attach some pictures they sent me.
[Re: Bakaruda]
#2696395
09/11/19 06:31 AM
09/11/19 06:31 AM
Posts: 1,111 Usa
A39Coronet
Usa
[Re: Jamey]
#2698806
09/18/19 10:05 PM
09/18/19 10:05 PM
Posts: 114 Katy, TX
Bakaruda
Katy, TX
I ordered one today from March. It will take a couple of weeks to get. When I get it installed I'll post pictures.
[Re: Bakaruda]
#2701104
09/26/19 11:57 AM
09/26/19 11:57 AM
Posts: 114 Katy, TX
Bakaruda
Katy, TX
I managed to get the system installed. Still need to clean it up.
[Re: Bakaruda]
#2701573
09/27/19 10:06 PM
09/27/19 10:06 PM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
I managed to get the system installed. Still need to clean it up. Looks slick
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
